Front Dana 44 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-17-2005, 02:29 PM   #1 (permalink)
BGibbs's Avatar
Member # 41054
Front Dana 44
I have read on the internet a couple times that a front 1978-1979 ford f350 front 60 is almost a direct bolt in for a YJ. Does anyone know if the same applies for the Dana 44 from the same years F250?
BGibbs is offline   Reply With Quote
Old 10-17-2005, 02:31 PM   #2 (permalink)
Member # 27407
Send a message via Yahoo to rticul8_94yj
Yes I believe it is the same.
How fortunate for governments that the people they administer don't think. Adolf Hitler
rticul8_94yj is offline   Reply With Quote
Old 10-17-2005, 02:58 PM   #3 (permalink)
Member # 48153
Send a message via Yahoo to yj-mule
Are you talking about width's? If that is the case then I would have to agree. I went a slightly different route than a D60 (for now) and I got the front and rear D44 axles from a Grand Wagoneer. They are 1/2 inch off in width WMS to WMS, and are perfect candidates for an SOA in my YJ because the rear axle on a Grand Waggy is already SOA
Edit Oct 18
A 1/2 inch of material inboard on both perches will need to be added and redrilled. On the front the axle is SUA so you will have to move them to the top. I have seen a lot of write ups on doing this, and the method I am chosing does not require any grinding of the housing. Good to know about the fords though for when I do go to an D60.
Is:92 YJ 4.0 AX15 NP231 D30 D35
Will Be: 92 YJ 4.0 NP435 NP205 D60 14 bolt SOA waggy spr.
[URL]http://www.rawsoftware.com/YJ-Mule/[/URL]
yj-mule is offline   Reply With Quote
Old 10-17-2005, 03:21 PM   #4 (permalink)
BGibbs's Avatar
Member # 41054
I was talking about the spring perches not having to be moved, to have them installed. I have read and have been told that you can just redrill the centering pin hole, weld up the old one and install SOA.
Old 10-17-2005, 04:16 PM   #5 (permalink)
Member # 27407
I have a D44 out of a 78 f250 and yes they are the same.
Old 10-17-2005, 05:41 PM   #6 (permalink)
BGibbs's Avatar
Member # 41054
Thanks,
How do you like it? What size tire are you running?
Old 10-17-2005, 06:24 PM   #7 (permalink)
Member # 27407
I guess ok. It's still siting on the floor next to my 60's.
Old 10-18-2005, 12:05 PM   #8 (permalink)
In Thx for chance
cisco's Avatar
Member # 37769
Originally Posted by BGibbs
Thanks,
i'm running a 79 f-250 hp44 in my wife's 88yj. it is very near bolt up. i redrilled the holes and had to get creative with the ubolts around the wide ass cast collar on the drivers side but it wasn't bad. we are running a 37 irok bias ply. no idea how it will hold up. haven't got it finished yet but we also geared to 5.38 and run the stock 2.5 liter! shouldn't break much. we'll see though!
...Sometimes nothing can be a real cool hand...
cisco is online now   Reply With Quote
Old 10-18-2005, 12:49 PM   #9 (permalink)
waterboy
surveyboy's Avatar
Member # 9086
I'm running the 78 f250 d44 also, running 36" Iroks. just becareful of binding the front in a couple of holes
http://members.cox.net/lwk/Pomona%20.../target48.html
http://members.cox.net/lwk/Pomona%20.../target49.html
if you keep outta holes, you can run stock shafts for a while ran most of last year with just a few breaks on stock shafts.
My uhaul truck turned rig hauler thread
Un-employed Spotter
surveyboy is offline   Reply With Quote
Old 10-18-2005, 04:40 PM   #10 (permalink)
BGibbs's Avatar
Member # 41054
Do you have a pic of the full jeep you could post? What size rim are you running? 16"? Just want to see what a 36" Iroc looks like on a vehicle with a rim bigger than 15s
