2.5 getting overbore - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-18-2005, 11:42 AM   #1 (permalink)
Member # 50162
I have a 2.5 out of a 95 yj that I have at the machine shop right now. The plan is a .060 overbore on it with new pistons and rings along with all new bearings and connecting rods. Also plan on putting a 4.0 throttle body on. Should I run new larger injectors also? Would 4.0 injectors fit? I don't know if the 2.5's run lean at wide open or not. But after the headwork, boring, exhaust, and intake are done, will it be to lean?
silver_silver is offline   Reply With Quote Quick reply to this message
Old 10-18-2005, 03:36 PM   #2 (permalink)
Member # 13176
It's really hard to say. If the injectors are in good shape, you may be OK. Hate to say it, but the single best way to find-out would be to hook-up a wideband air/fuel ratio guage/datalogger once it's in. If you need larger injectors, the stock 4.0 injectors should be a direct swap. Ford Motorsport 19 lb/hr are also a good injector - same flowrate as older 4.0 injectors with a better spray pattern.
Brian Lucero
SubCulture New Mexico
www.subcultureworldwyd.net
SubCultureNM is offline   Reply With Quote Quick reply to this message
Old 10-18-2005, 04:08 PM   #3 (permalink)
Member # 50162
Do you have any idea what the ford injectors would come out of? I can get used 4.0 injectors for free, but I might spring for new ford injectors if they are cheap enough.
Old 10-18-2005, 07:10 PM   #4 (permalink)
Member # 13176
Fox-body Mustangs (fuel-injected 302s from late '80s to early '90s) used that injector - you can usually find them cheap on eBay. I heard about them from XJ guys that used them as a cheap replacement for leaky stock injectors. They claim the spray pattern helps driveability - I had them in a '90 XJ.
Brian Lucero
Old 10-18-2005, 07:12 PM   #5 (permalink)
Member # 13176
Fox-body Mustangs with the 302, from mid to late '80s to early 90s. They're typically pretty cheap on eBay.
Brian Lucero
