Removing TC Drop - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-18-2005, 04:12 PM   #1 (permalink)
Member # 51586
Removing TC Drop
I'm looking to remove my TC drop since I now have a SYE. THe shop that installed the SYE would not remove the TC drop for some reason.
Anyways, as I am a Jeep newbie and I want to learn how to do things myself, could someone please let me know the procedure; I know I need a jack, but do I have to disco the driveshaft? Anyone know what size the stock bolts are so I can buy some? Any other tips or tricks I should know? Thanks in advance.
Roscoe P. Coltrane is offline   Reply With Quote
Old 10-18-2005, 04:31 PM   #2 (permalink)
hotwheelsYJ's Avatar
Member # 32401
Send a message via Yahoo to hotwheelsYJ
The bolts are 1/2-13 probably 1-1.25 long
Put a floor jack under the belly pan
Loosen all 6 bolts, remove one side(3 bolts)
lower jack enough to get out spacer
jack back up & put in shorter bolts
Repeat for other side
tighten all bolts and check angle & clearance of front & rear Dshafts
Shouldn't take any longer than 20 minutes
www.WILSONPERFORMANCE.com
hotwheelsYJ is online now   Reply With Quote
Old 10-18-2005, 07:00 PM   #3 (permalink)
Member # 2769
Did the TC drop hardware come with a lift kit?
Probably so ...
Why? Because you've changed your drive shaft angle and the drop is to prevent U-Joint vibrations and binding.
Solution ... a drive shaft witha CV style U-Joint on the TC side.
Added "issue" ... you will probably need to rotate your rear end pinion angle to point to (just under) the new CV yoke where-as a conventional U-Joint setup needs the yokes to point parallel with each other.
Check out the tech sections of some of the major driveshaft manufacturers. They usually have show-and-tell discriptions and diagrams on proper drive shaft geometry.
Jaffer is offline   Reply With Quote
Old 10-18-2005, 07:21 PM   #4 (permalink)
Low Range Drifter
JohnnyJ's Avatar
Member # 7903
If the spacers are plastic then it should be a quick job.
If they are aluminum, you might be in for a fight if the spacers have corroded onto the bolts. I've had this happen, and it's no fun. One broke free with liberal amounts of heat, the other was removed with a sawzall.
I've seen some get lucky with lack of vibes and no pinion adjustments, but others have required adjustable control arms to cure.
DEAK Racing #715 TREC B / Ultra 4 Mod Class Rig
Thanks to Drivetrain Specialists and PAC Racing Springs for your support
JohnnyJ is offline   Reply With Quote
