#1 (permalink) | |
nth degree zig zag
has anyone seen this set up or have one in use? i have a friend looking to install it and he and i are picking it apart from what we can find on nth degrees site and from a few tidbits on the web. anyone have any input on this thing?
http://www.nthdegreemobility.com/zig-zag.htm i think this might actually be the rig i saw it on ![]() ![]() ![]() ![]() from their site Quote:
The mountains are calling and I must go. -John Muir |
IMO it's just another gimmick to gain flex just like revolver shackles and z boxes. Not needed IMO. Just my opinion and we know what that’s worth.
How fortunate for governments that the people they administer don't think. Adolf Hitler |
Member # 52575
My question on that thing has always been from the physics side...
How in the world is "droop" from that thing any good when there is no reverse force or pressure being applied to the tire. Under load (i.e. when you need traction and thats what "droop" is for) that tire won't do any good because any rotation of the tire will not have any downward "force" or pressure exerted to it anyhow, thus making the whole application useless. Am I wrong here or what?
Member # 38743
In response to jeepguy and also from a physics side, what downward force would be exerted on the axle if the spring was secured to the frame by a standard shackle? A leaf sprung axle under full droop experiences some minor up force from the spring, and no down force from the spring, so i don't think that this system would take away from traction any as compared to a standard leaf spring.
Personally I don't like the idea of having my suspention droop so easily, i'll bet the rig wouldn't be as horizontally stable in off camber situations, but i've never seen one in action. Last edited by BassPlaya799; 10-19-2005 at 01:07 AM. |
#6 (permalink) | |
Member # 30432
I think if the rig is going to only compete on an RTi ramp it might be a good setup. But if it is going to decend from any ledges, Im betting that it will be bent fast. Just my .02 JOSH
SHOP AND APPARTMENT FOR SALE [url]http://pirate4x4.com/forum/showthread.php?t=589523[/url] |
Member # 38716
my theory on this is look how many people arnt running this setup, I have never seen one one the trail, but i remember reading an article in 4wheel drive awhile back about them. I agree with speedcravin about how it may score better on an rti ramp but have a negetive effect on the trail.....i wouldnt put it on..........
America is all about Speed. Hot, Nasty, Badass Speed...... |
Member # 6340
Location: Telluride CO, within site of of Black Bear Pass
No thanks.
I see no real gain and lots of potential problems with this type of set up.
Marc In what appears to have been an understatement, the plant operator described the situation at the Number 4 reactor as "not so good." Super conversion calculator website Love and kisses, Zaphod.. |
#9 (permalink) | |
Member # 52575
And as another poster mentioned, imagine driving down a steep slope or a steep off-camber spot and having the rear end unload rapidly on a bump ... endo or roll city! This system is NOT for me!
Fistful of Boomstick
besides the uncontrolled drop issue there is a few others:
remember to "lock" it in place when on the street, unlock for the rock,lock for the decent,unlock for the ditch, lock for the.....you get the idea The lateral stability of your entire rear suspention being held in place with a couple of hiems that are now a rock target at the very end of your vehicle and made of .125 wall tube
Doc-14 Tactical Products: When it absolutely, positively needs to be made from random crap found in the back of my garage. You cant ban knowledge, learn to make your own guns right Here. New York, Colorado, Maryland, Conneticut….is your state next? Yes it is. Write, Vote and Fight. |
Moderator
I also don't see a shackle in any of the pictures. Is there one?
Check out our new Team Ape Eater Racing Like us on FaceBook KF5EQF Sniper Fab 4x4Oil SBwinVPS Custom Splice C2GFab |
#12 (permalink) |
Member # 784
Its not entirely true that you have no downward force on the mega-drooped tire. The spring on the other side of the vehicle is still supporting the rear portion of the vehicles weight.
Since the spring is not located directly above the stuffed tire, some of that force travels to the drooping tire. How much is dependant on several factors. But...that does not mean you want uncontrolled poser-ramp-champ droop. That thing is just like revolvers, buggy springs, goober leafs, and all that other crap. Just a gimmick
Think for yourself |
#13 (permalink) | |
Member # 784
That blue bracket in the top pic has a flat surface on the bottom, covered in nylon or some other plastic. That is your shackle
#14 (permalink) |
Moderator
oh, nice...
#15 (permalink) |
Member # 30432
I like a lot of nthdegree's stuff but this is not one of them. I realize most dont drive as hard as I do but imagine what would happen to the rear axel if you were to roll the jeep over. Im thinking that the (ONLY) mount point, "im going to call it the panhard bar" is not the strongest suspension mount I have seen.
to each its own. JOSH
#16 (permalink) |
Member # 47487
Show truck stuff. 1. Off camber would be bad with that setup. I think you would be much more likely to roll. 2. more stuff to break and fix, looks like it would get smacked on exit. 3. unless there is some way to 'lock it' in place, it would be a bitch on pavement, everytime you turn a corner you would flex way out. 4. what happens to it in a roll????
I don't like repeat offenders, I like dead offenders. Mr. Ted Nugent |
#17 (permalink) | |
#18 (permalink) |
Member # 36311
Revolvers and the 9th are about the same......
1. One wheel goes up the pressure....The other goes DOWN with the SAME pressure.... So unless you center and both are springs are hanging you would have down pressure........... I would bet a stock type shackle would lift and leave you centered before either of the two drop shackles.... 2. Limiting strap would be the key for both. 3. You can lock the 9th and side hilling could be hard BUT what about all the coil spring guy's and high as hell SOA... Oh Ya they side hill really well..NOT... 4. Hard braking...... Yes If you hit them hard they will unload...Ummm just like any flexy suspension........ 5. They should only be run with SUA... That is what they were designed for... 6. Cheap flex($200) that might help some and hurt others???? I would take them over buggy spring set-up... and if you want them?? Make sure you know what and how they work….
Slow and Go, That is the tempo. [url]http://www.putfile.com/bfg35yj[/url] |
#19 (permalink) |
Member # 15424
more stuff to break
spring under flex aid I have tested the limits of buggy springs and I do not care for more moving parts. I also matured and my driving style demanded a properly setup spring over swap. I would never use this, but have to admit I did buggy springs and have negative things to say about them.
90YJ | HDOR | WEBILT | ID4x4A |
#20 (permalink) |
Member # 44219
OK. I have 4 corner shackle revolvers on my 7 and I like them very much. I have quite a lot of droop witrh them. The whole theres no weight on the tire for traction doesn't hold water. There is the same amount of weight on the tire thats drooping as a rig w/o revolvers. Think about it? The only thing pulling either set-up down is it's own weight. The only difference is the one with the revolvers can travel down farther. I know most people don't understand that, but it's the truth. Take 2 rigs one with revolvers and one w/o. Take them over the same obstacle where they will get a lot of droop. The rig w/o goes over and the spring flexes and the tire is abbout 4" from reaching the say rock. Ok, the rig with them does the same thing, but the revolver lets it touch the rock. No it doesn't have full weight on it cause it's all on the other side for both rigs. But that tire touching is still doing more work then that tire in the air. Is it not? And they don't unload on off camber spots. Thats all internet rumor spreading crap from people that haven't used them. The only complaint I got from people actually using them was bad axle wrap and wheel hop on SOA rigs. And most said an anti-wrap bar took care of both.
But the whole thing about no weight and traction is false. Cause both set-ups have the springs attached to fix points. ust think of the revolvers as a better drooping spring, cause thats all it is. And again, no matter if you have them or not, the tire drooping only has it's weight of the tire. spring and axle applying downforce period. |
#21 (permalink) |
Member # 24992
Droop is overrated. Traction is the key. Save your money for a good locker and then it doesn't matter if that tire is slightly touching the ground due to fancy droop or hanging in mid air.
My TJ buddies with their slinky's occasionally like to poke fun at the non-flexy SUA YJ. In the end though, the non-flexy square headlights follow the fancy slinky's everywhere they go. Once you're locked front and rear you don't always have to have all four on the ground.Sure those super flexed crossover shots look great, but tires hanging in midair always make for a great pic too.
5.9 ZJ on 31's - Wife's DD. '94 YJ - RE 4.5XD, 1" BL, Waggy 44's, 4.88's, ARB's & 35's. |
#23 (permalink) | |
www.12voltguy.com
Member # 40
looks captured enough I can't see that happing
12voltguy info@12voltguy.com--davezoffroadperformance.com # 530.532.4529![]() TTC 2010 1989 BRONCO -Awesome web development for your business. www.mudnworks.com mud@mudnworks.comPat's W I D E TOYOTA Front Axle --07 KTM 450XC----with "stuff" |
#24 (permalink) |
Member # 30432
I dont think you will notice any rear steer
... Although with any suspension, when one side is at a large droop, that side of the axel is closer than the side that is higher or (stuffed). Since we do not drive any distance that way we do not notice it. But imagine driving that way for 40 or 50 feet... it will cause a rear steer situation. Its not just the Zig Zag, it works the same with any suspension.. JOSH
#25 (permalink) | |
How fortunate for governments that the people they administer don't think. Adolf Hitler Last edited by rticul8_94yj; 10-23-2005 at 10:14 PM. |
