Member # 45287
CJ7 manual tranny fluid??
1983 CJ-7 T-5 tranny, what fluid does this take..The manual stated a "Chrysler manual lube part # so an so"...I would assume since it's a T-5 that it would take ATF but just not sure..Thanks
Member # 6340
Location: Telluride CO, within site of of Black Bear Pass
Torch off.
Hey crawl under there pull the fill plug, stick your finger in and if red its ATF, if it brown and smelly like a girl named shelly then it's 90w.
Marc In what appears to have been an understatement, the plant operator described the situation at the Number 4 reactor as "not so good." Super conversion calculator website Love and kisses, Zaphod.. |
skullfuckery
Member # 29016
do you know what the "A" in atf stands for?
put it in if you want, its not going to hurt it, or some 80-90 gear oil is my favorite. just so you dont think im full of it, a 205 tcase is listed with different fluids for different vehicles, runs any thing from 10-30, 80-90 and atf depneding on the vehicle manual.
Impeach or revolt, which will it be? buy my quad http://www.pirate4x4.com/forum/vehic...00-2500-a.html I WILL TRADE FOR A ROAD WORTHY 55-57 or 71-87 CHEVY 2WD PICK UP |
#5 (permalink) | |
Member # 45287
#6 (permalink) | |
Member # 45287
Member # 54600
The vescosity of the chrysler oil is similar to ATF, too bad IIRC it costs 9 bucks a quart.
There are issues with not using the chrysler oil, it has something to do with dergents or stabalizers or some other additive. Not using the recommended oil can and most likely will carrode the bronze syncros. I've heard this happen in the t-5 and I've seen a 5-speed muncie (similar to the Getrag 260) in a chevy truck blow within 500 miles after the non-GM oil was put in. Unless someone can say they run their t-5 with the non-Chrysler oil and it has survived, i would go with the dealer recommended oil. Better yet, throw that t-5 on the curb and at least get a ax-15...or a muncie 420
Wheel it to break it to fix it to wheel it. 84 [COLOR="Red"]C[/COLOR][COLOR="White"]J[/COLOR][COLOR="Blue"]7[/COLOR], Runs on alcohol ([COLOR="Red"]Old Mil[/COLOR]). 1984, 7, 100", 38s, 44s, 5.38s, 350, 465, 300, 92:1 Last edited by BildoStyle; 10-20-2005 at 08:03 PM. |
#8 (permalink) | |
Member # 45287
Member # 15668
I ran 75/90 for 8 years no problems Sold it when I repowered and the new owner reports no problems. There are 2 versions of the T5 and some will use ATF. As I understand it, it depends on your mainshaft bearings(taper or ball) and the variance was in the '82-'83 series CJ's
#11 (permalink) | |
Member # 45287
#14 (permalink) |
Member # 55670
ok so hows this for a question i drained my T4 and i now have a thick Goo in the case its so thick it will not run out. its a mix of ATF and 80w90. what do you guys use to flush your transmissions?
thanks for helping. Jake
Screw the New guy Teach him to fix it then steal it. Last edited by Cjeeper86; 10-21-2005 at 06:11 PM. |
#15 (permalink) | |
Member # 45287
#18 (permalink) | |
Member # 45287
#21 (permalink) |
Member # 54600
mine is about to come apart and the 75/90 will be put in. I lost 5th and rev is messed up, fells like the linkage is broke or something similar. Anyone have an ax-15 for sale?
Wheel it to break it to fix it to wheel it. 84 [COLOR="Red"]C[/COLOR][COLOR="White"]J[/COLOR][COLOR="Blue"]7[/COLOR], Runs on alcohol ([COLOR="Red"]Old Mil[/COLOR]). 1984, 7, 100", 38s, 44s, 5.38s, 350, 465, 300, 92:1 |
