add a leaf verses spring pack - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-22-2005, 08:52 PM   #1 (permalink)
Member # 43239
OK , I looked at all strings in this forum before I posted this.
I have a 97 XJ that I think needs a little boost. 3 inches would look about right I think. My (first ) question is, I have no spring sag , so would an add a leaf work for me in the rear or should I go with a full spring pack ?? I would like to go to a little larger more aggressive tire
Ridr is offline   Reply With Quote Quick reply to this message
Old 10-22-2005, 09:34 PM   #2 (permalink)
Member # 33991
Add a leaf will work, but will change the spring rate, IE make things stiff. IMHO better to go with new packs of the right height. Ive ridden in both, and new packs are much smoother, and flex better to boot.
lilgreenjeepyj is offline   Reply With Quote Quick reply to this message
Old 10-23-2005, 05:13 PM   #3 (permalink)
Cherokee_HxC's Avatar
Member # 53490
i absolutely advocate a new pack, ive not had any problems (sagging or otherwise) with my newest rear end. yet ive heard enough sagging stories from the add a leafs to deter from that route
just kickin it like a wild donkey
Cherokee_HxC is offline   Reply With Quote Quick reply to this message
Old 10-23-2005, 05:58 PM   #4 (permalink)
Member # 43239
thanks guys !!
Old 11-04-2005, 07:52 AM   #5 (permalink)
piratebuggy's Avatar
Member # 53597
add a leaf will stiffen up the ride beyond belief.And strain the other leafs-better to go with new leafs or recurve what you got IMHO.
piratebuggy is offline   Reply With Quote Quick reply to this message
Old 11-04-2005, 08:52 PM   #6 (permalink)
Member # 55459
Send a message via AIM to CreativeSN
How much does recurving usually run?
CreativeSN is offline   Reply With Quote Quick reply to this message
Old 11-06-2005, 05:59 AM   #7 (permalink)
Member # 53597
It's cheaper than a new set of springs and the results are pretty good from what I've seen.Not sure on the prices-I usually get stuff wholesale being a pro wrench-hate me -I understand.
Old 11-06-2005, 05:04 PM   #8 (permalink)
Member # 53675
Send a message via Yahoo to jeepingforChrist
One thing I have heard done and I am gonna do is to take two sets of leaf springs and combine them, it only makes about 2 in of lift but it is an idea. Just make sure and cut off the bolt eye for the extra main leaf.
1970 Jeepster Commando(soon to be running) for off-road use only
Warner T-86AA 3 Speed
Spicer 20 T-Case
Dana 27 Front
Dana 44 Rear
1991 Jeep Cherokee Laredo-Lift off-roader and DD
jeepingforChrist is offline   Reply With Quote Quick reply to this message
