Leaking TJ Woes - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-23-2005, 03:48 PM   #1 (permalink)
Member # 40587
Leaking TJ Woes
I searched this topic and didn't find anything on TJs so...
I bought a 98 TJ sport for a Daily driver a few months back, recently i noticed that i have a serious leak in my passenger firewall area. I'm well aware of the leaky jeep areas in my YJ, so i checked the cow udder, i took the cowl panel off the TJ sealed up all the areas where i thought water could get in. I then noticed that after putting the garden hose into the cowl area that the water was leaking from what appears to be the AC condenser box (the box that is connected to the water drain tube that emptys into the engine compartment. It also appears that there is also a foam donut in between the firewall and the condenser box that looks like a seal but it doesn't look like its in bad shape. Is this a typical problem that anybody else has experienced? I'm getting frustrated that I'm being defeated by a damn leak. Any help would be appreciated before i go mad doctor on my dash.
Please keep in mind as well that this is my daily driver and not my wheeler, I would rather fix the problem correctly rather than pull out the carpeting and pop the drain holes.
The Black Sheep is offline   Reply With Quote
Old 10-23-2005, 04:11 PM   #2 (permalink)
Member # 48153
Send a message via Yahoo to yj-mule
A friend of mine just bought an 2001 TJ and it leaked like a sive in the same area. If I remember correctly he got it corrected. I will ask him and see what he did.
Is:92 YJ 4.0 AX15 NP231 D30 D35
Will Be: 92 YJ 4.0 NP435 NP205 D60 14 bolt SOA waggy spr.
[URL]http://www.rawsoftware.com/YJ-Mule/[/URL]
yj-mule is offline   Reply With Quote
Old 10-23-2005, 09:30 PM   #3 (permalink)
Member # 20525
I had a 97 tj that leaked at the same spot. It would leak while running the AC or in heavy rain. I added a 90 degree turn down with a small section of plastic tubing and silicone sealant around where the drain came out of the firewall. no more wet carpet.
85 toy, 22re, 5spd,5in susp lift,5.29's & detroit,ruf,chevys,longs,etc
poolman450 is offline   Reply With Quote
Old 10-25-2005, 01:19 PM   #4 (permalink)
Member # 22536
Here's what I did. http://www.pavementsucks.com/forums/...hp?topic=78788
I can see the liberal Movie (eeeESCAPEe FROM MEXCIO) Starring V Fox AS PEP'E the fence orniment!
[COLOR="Red"][SIZE="5"]ΜΟΛΩΝ ΛΑΒΕ[/SIZE][/COLOR]
For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and there you will long to return.
Leonardo da Vinci
Tufiremn is offline   Reply With Quote
Old 10-25-2005, 08:31 PM   #5 (permalink)
Member # 40587
Sweet! just the answer i could have hoped for. Thanks
