YJ wipers/motor SLOW - any one else - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-23-2005, 07:33 PM   #1 (permalink)
Member # 48153
Send a message via Yahoo to yj-mule
I have a 93 YJ and my wipers are annoyingly slow. I believe there are three speeds, slow, slower, and stopped not counting the off position.
Does anyone else have this experience? Is there a way to fix it?
I was thinking about puting in a wiper motor from a TJ or some other vehicle that was faster after figuring out if it fit or not. Or is something just busted?
TIA
Is:92 YJ 4.0 AX15 NP231 D30 D35
Will Be: 92 YJ 4.0 NP435 NP205 D60 14 bolt SOA waggy spr.
[URL]http://www.rawsoftware.com/YJ-Mule/[/URL]
yj-mule is offline   Reply With Quote
Old 10-23-2005, 08:09 PM   #2 (permalink)
Member # 40587
Its entirely possible and probable the motor is cooked. Had the same problem with mine, just make sure that nothing in binding too.
The Black Sheep is offline   Reply With Quote
Old 10-24-2005, 08:12 AM   #3 (permalink)
Rattlecan's Avatar
Member # 50639
My 89 has the same wiper speeds as yours. Really slow, slower, and stuck. All when in the on position... If there is mud on the windshield they get stuck. If you have any luck with a TJ motor please post up...
Rattlecan is offline   Reply With Quote
Old 10-24-2005, 08:16 AM   #4 (permalink)
Rattlecan's Avatar
Member # 50639
Just did a quick search on e-bay. Seems there is a brand called Wipe Boy that sells upgrade kits. Might be something to look into
Old 10-24-2005, 12:42 PM   #5 (permalink)
Member # 48153
I took a look at them, but it only looked like their setup was to change the angle of the blades so that they start flush with the bottom of the windshield instead of up off of the bottom.
In addition they are supposed to provide a larger wiping surface. I never thought about the fact that they might have a better motor.
I will take a look, maybe call them, if I come up with something I will let post my results.
UPDATE -
I looked up the kit contents and it contains a new wiper motor arm, linkage, and wiper arms. No motor changes.
QUOTE: "upgrade kits increase the sweep angle of your windshield wiper system..."
Great idea though.
Old 10-24-2005, 01:07 PM   #6 (permalink)
crawlinyjeep's Avatar
Member # 29220
Send a message via AIM to crawlinyjeep
Is anything else funny blinkers headlights, cuz it can also be your control computer located under your column. there is a medal plate with two screws in it take it off and check it out went to pick and pull got one for 5 bucks now mine work great
Also try to unplug clean it out with air the plug it back in and see if it helps
92 3/4 ton yj stretched locked up on 44 14.50 20 bling bling rolled at seventy daily driven
crawlinyjeep is offline   Reply With Quote
Old 10-24-2005, 04:31 PM   #7 (permalink)
Member # 53637
Send a message via ICQ to magsnubby Send a message via AIM to magsnubby
Chrysler calls it the intermittent wiper relay. It's marked INT-WIPER on the module. It's on a metal plate on the left side of the steering colum. If your wipers aren't working at all or only one speed works then it could be the wiper relay.
You can by pass it but you'll only have one wiper speed. Slow. Just pull the relay and plug the two wiring harnesses together.
magsnubby is offline   Reply With Quote
