Can't Drop Second - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-23-2005, 10:27 PM   #1 (permalink)
Member # 56093
Can't Drop Second
Variables that need to be considered:
1998 4.0l 5spd, with 33's and RE 3 1\2 super flex
Ever since I installed my 3 1\2 rubicon express superflex, shifting into second has been harder than usuall. Since I've gotten used to it, but after a recent trip to hollister shit hit the fan. About to begin a trail, I wasn't abble to shift into first or second gear. After playing with it for a while I was able to keep it in first. The whole trip back I had no second gear, and still don't. I took a peak under the tub and I think it's hitting the side of the of body when going into first in second. Where can I find out how to repositioning the linkage so it will no longer hit? Also if you know of any other reasons why this problem (Not able to get into 2nd)would occur. I'd be doing all the work, so Im just looking for a second opinion before I start tearing this thing apart, so I can work smarter and not harder.
Thanks,
Rob
1998 Wrangler: White, Rock Crusher Front and Rear Bumpers and Tire Carier, On board Air, 33'' tires, 3 1\2 Rubicon Express lift. PowerTrax Rear Locker, Procomp Wheels, Step On it Rocker Guards, Sony Deck, and of Course Fabed by Palu...
Palution is offline   Reply With Quote
Old 10-24-2005, 06:56 AM   #2 (permalink)
Jerry Blair's Avatar
Member # 10761
Probably just hitting the transmission cover. Trim it to fit and you will be fine. I've had the same problem with several TJs with the drop transfer case skidplate.
Jerry Blair is offline   Reply With Quote
Old 10-24-2005, 05:34 PM   #3 (permalink)
Member # 56093
I took a look under it today, and the whole drive line seems out of alignment. The rear driveshaft seems to be out of alignment towards the passenger side of the vehicle. Possibly the tranny mount is broken?
Old 10-24-2005, 07:02 PM   #4 (permalink)
ne14jpn's Avatar
Member # 42619
Send a message via AIM to ne14jpn
tranny mount or motor mounts
-Erik
Miller Motorsports #4421
www.millerrockracing.com
ne14jpn is offline   Reply With Quote
Old 10-24-2005, 09:13 PM   #5 (permalink)
Moderator
apeters89's Avatar
Member # 7647
step one: check the tranny, motor mounts.
if those are good then go to step two, otherwise replace then, then go to step two
step two: check to make sure the shifter is not hitting the body tub inside your shifter boot. Moving the tranny down (skid-plate/t-case drop) will cause the stick to travel through a different/longer arc which causes it to hit the tub.
if this is the case then cut the offending body tub pieces away.
Check out our new Team Ape Eater Racing Like us on FaceBook
KF5EQF
Sniper Fab
4x4Oil SBwinVPS Custom Splice C2GFab
apeters89 is offline   Reply With Quote
Old 10-24-2005, 09:32 PM   #6 (permalink)
Member # 46710
The rear diff on TJs, at least ones with the d35, do have a slightly offset driveshaft to the passenger side.
I am guessing you installed a t-case drop kit with the lift, which will alter shifting. I've heard some say they took care of the problem by removing the rubber shifter boot.
good luck
go watch my videos - youtube.com/mugreentj
mugreentj is offline   Reply With Quote
Old 10-24-2005, 10:23 PM   #7 (permalink)
HeiserOilMotorsports
Member # 1515
Send a message via AIM to Po' riggity Send a message via Yahoo to Po' riggity
sounds to me like you need to trim the body away under the shifter boot.
Scott
Black Star Status!
Po' riggity is offline   Reply With Quote
Old 10-25-2005, 08:18 AM   #8 (permalink)
Member # 47730
some kits give you a little drop piece, if you dropped your transfercase you have too use this too keep the linkage in line. with a tailshaft kit it is not needed. it mounts to your linkage right under the shifter and it uses 4 bolts.
2nuts4u is offline   Reply With Quote
Old 10-25-2005, 10:36 AM   #9 (permalink)
Member # 47179
Send a message via AIM to TotalImmortal
back in the day when i had a tranny drop i removed the shifter boot and all my problems faded away.....
Brice
TotalImmortal is offline   Reply With Quote
Old 10-25-2005, 05:13 PM   #10 (permalink)
Member # 56093
Thanks for all the replys, I ordered a new transmission mount and we'll see if that fixes on thursday.
