Jeep has a slight miss at idle... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-23-2005, 10:40 PM   #1 (permalink)
HeiserOilMotorsports
Member # 1515
Send a message via AIM to Po' riggity Send a message via Yahoo to Po' riggity
The jeep has a slight miss at idle, and won't pass smog due to the miss. Ive checked all the vacuum lines, and thats not the issue. Anyone know what it might be? Im about ready to give up and just give it to a smog shop to let them figure it out, but I don't want to spend the $$ right now, as I don't really have it. The problem is, my temp moving permit expires at the end of the month, so I need to move it to a smog shop SOON if I can't figure it out on my own. Any ideas will be appreciated.
Scott
Black Star Status!
Po' riggity is offline   Reply With Quote
Old 10-24-2005, 12:27 AM   #2 (permalink)
Banned
Member # 36563
Replacing the Throttle Positioning Sensor fixed a miss at idle I had on a '94 ZJ.
conefoot is offline   Reply With Quote
Old 10-24-2005, 10:38 AM   #3 (permalink)
Member # 56112
Send a message via Yahoo to Danzig13
yeap the (TPS)throttle positioning sensor was wore out and my jeep had just a slite miss at idle....but when the TPS got more ware on it the transmission wouldnt shift at all...there are ways to test it with a volt meter (it may have a dead spot in the sensor)
Danzig13 is offline   Reply With Quote
Old 10-24-2005, 12:13 PM   #4 (permalink)
Member # 32364
Send a message via AIM to TSM_88YJ
EGR valve? Mine was messed up and caused a sort of a rough idle, hard to explain, so I cut it off and welded that plate shut. problem solved. but I live in bfe NC so smog aint a problem.
CENSORED SIG: To view press alt+f4
TSM_88YJ is offline   Reply With Quote
Old 11-02-2005, 09:56 AM   #5 (permalink)
jeep_collector's Avatar
Member # 42449
Your post just doesn't provide enough info to really help you. It could be several different things. I went through this on my 90 YJ.
I found this website to be helpful when trying to pass smog:
http://www.off-road.com/jeep/tech/258bbd/
What are your smog readings? They can help identify the problem. How does the Jeep run in general?
jeep_collector is offline   Reply With Quote
Old 11-02-2005, 07:54 PM   #6 (permalink)
Member # 15424
Scott
so is it on your 89?
do you have the factory carter BBD? stepper motor? 75.9 miles of smog equipment?
I have lots of questions, and more than likely some more that you wont be able to answer if its an 89. SMOG ONLY right?
A fully functional carb and electronics are really hard to accomplish on that rig. I tried three times in my 90 in Sacramento county, one more strike and they were gonna take the rig. I went mopar fi in the end, but did alot of mods to try and pass smog. Let me know some more details and I will do what I can.
90YJ | HDOR | WEBILT | ID4x4A
gripguru is offline   Reply With Quote
