Newbie
NV3550 to AMC 304
Ok, got a few questions about the NV3550. I’m looking for a trans for a DD CJ-5 that will be running 35”/36” tires and 4.88 gears. The jeep will see mild offroad use, but mostly city and highway.
Has anyone or does anyone know how to mate the NV3550 up to an AMC 304? Also, I’m assuming that the NP231 is a direct match for this transmission, is this correct?
---------------------- BUILT not bought!! 87' YJ 4.2L w/ 4.0L head swap, Ford T18A, Mopar Performance Dana 44 axles and 36x13.5 Irok's 79' CJ-5 - waiting its turn in the garage |
Low Range Drifter
Member # 7903
Jeep nv3550 is stock 23-spline np231. You would likely be better off running a d300, which will bolt on with no spacer required (unlike the AX-15). (Assuming you're running stock axles, that would match the pass drop axle.)
258, 304, 360, 401, 4.2L, 4.0L, all have the same block bolt pattern, so bellhousing will bolt up. Potential issue would be clutch disk and pilot bushing. The nv3550 also uses a hydro clutch, so be sure to grab the master & slave cylinders. You'll have to modify your clutch setup to use the master.
DEAK Racing #715 TREC B / Ultra 4 Mod Class Rig Thanks to Drivetrain Specialists and PAC Racing Springs for your support |
#4 (permalink) | |
Naw , We have a crawler here that runs a cj2a ford 302 c4 and a dana 20 with a ford 9 in the rear. If he can get away with a V8 and a auto in a CJ2a then a 3550 isnt too long for a 5
Industrial Quality CNC machines at a Hobby Price! USA Quality is job #1 We build CNC plasma tables, click me .................................................. .........![]() American Motors Engine HERE!! 1-651-257-7917 |
Member # 20198
Rear driveline will be about 10 or 11" long with a D300 and the 3550.
Advance adapters makes a pilot bushing that will work.
[COLOR=RoyalBlue]This Space Intentionally Left BLUE[/COLOR] |
