Low Range Drifter
Member # 7903
Look in the FAQ under "Inside Gas Tank Locations"
DEAK Racing #715 TREC B / Ultra 4 Mod Class Rig Thanks to Drivetrain Specialists and PAC Racing Springs for your support |
Member # 41947
In the middle of doing mine.
Important links: http://store.summitracing.com/defaul....asp&x=25&y=16 http://www.pirate4x4.com/forum/showt...ight=RCI-2161A http://www.pirate4x4.com/forum/showt...t=tj+fuel+cell http://www.pirate4x4.com/forum/showt...t=tj+fuel+line My cell: ![]() ![]() I am going to change the mount by laying the cell on the tub instead of on rubber mounts and running straps over it. Also, I am going to run steel braded lines inside the bad to the engine. I don't have a top and the exhaust is on the driverside. Last edited by iispms; 10-24-2005 at 10:30 AM. |
Member # 41947
Yes, that is the factory one. You cut a hole in the cell and make three rings.
http://www.pirate4x4.com/forum/showt...ight=RCI-2161A |
Low Range Drifter
Member # 7903
There are currently 4 threads that are "stickied" at the top, it's the one named "Important: The 'Official Jeep Talk FAQ' v2.0".
It has the original version of what iispms did posted and mentions part numbers and pieces made.
Member # 38716
why do you want to lay the cell directly onto the tub, i heard that it may cause the tank to crack. Not that the body flexes that much, but the reason im asking cause i have that exact same setup/tank waiting to be mounted in mine when i finish with some other stuff................
America is all about Speed. Hot, Nasty, Badass Speed...... |
Member # 31285
Pumpkin, I think its a weight issue, with it elevated by 4 corners thats alot of fuel sloshing around and weighting it down...Tab's bend, welds break, fuel leaks.
-Joe
Rock Posse Racing #686 Driver: Joey Weber |
Member # 179366
when searching for fuel cells in a TJ i came across your post
i have been looking online for tanks and what not i can find tanks for around 200 and then a kit that is 500 bucks?? did you have to buy some 300 dollars worth of hoses and ends and fittings? any help would be greatly appreciated thanks the kit i have found is the following RCI 2161A Fuel Cell & Jeep TJ Install Kit Package |
#11 (permalink) | |
Here's Johnny!
Member # 12867
You can quickly spend a good chunk of money on fittings, hoses and misc stuff. $300 worth might be difficult to say, you can look up everything that they has listed there and put a price on it. Might be worth the convenience of buying it all in one place and only having to deal with one vendor.
#12 (permalink) |
Member # 87845
I cant believe some vendor hasnt put together a single order parts kit for this yet...
maybe even with all the fuel lines cut to length, fittings fit, so you blot it in, and go... I bet it would sell if it was out there... not my style (I like to do things the hard way cause im an idiot, and usually end up costin g myself more in tools, do-overs etc) but im sure someone would buy it. |
#16 (permalink) |
Member # 179366
i have been searching and clicking and reading and everything
found somewhere that a person used Hydraulic fittings instead of the AN fittings which could save a little money but then you just have to figure out which size fittings you need and blah blah i would think it would be as simple as putting in cell and hooking up lines that are currently there from the old tank to the new cell but nope |
