ecu... 97 tj engine in a 95 yj - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-24-2005, 01:39 PM   #1 (permalink)
Member # 33498
I might buy a friend's 95 yj... he threw a rod in it last year, so I helped him put in a 97 tj 2.5l engine to replace the old yj 2.5l. If it buy it, it will need a new ECU because it went out. Should I buy a YJ ecu or a TJ ecu?
wiggamoe is offline   Reply With Quote Quick reply to this message
Old 10-24-2005, 01:50 PM   #2 (permalink)
Member # 7903
It will depend on how you did the swap was done, so I'd ask him if he kept the YJ ECU or swapped in the TJ ECU.
JohnnyJ is offline   Reply With Quote Quick reply to this message
Old 10-28-2005, 09:45 AM   #3 (permalink)
Member # 33498
He kept the YJ ecu. Upon completion of the swap, then engine ran REALLY rich for 6 months until the jeep stopped working.
Old 10-28-2005, 11:44 AM   #4 (permalink)
Trailer Guy's Avatar
Member # 49181
I would run the ecu that comes with the motor. 97 with 97 - 95 with 95. Running the other ecu might be why it ran rich and died. I don't think you ever what to mix ecu's with different motors. I'm sure some have done it with out problems though.
Better to die fighting for freedom then be a prisoner all the days of your life. -Bob Marley-
Most people do not really want freedom, because freedom involves responsibility, and most people are frightened of responsibility. -Sigmund Freud-
Trailer Guy is offline   Reply With Quote Quick reply to this message
