NP231 swap out
Hey i busted my NP231 the other day(put a hole in the rear of it) and i was gonna switch it to my friends NP231 that came out of his 94 cherokee. Mine came out of an 87 Wrangler. Mine has a vacuum line and his is electrical. Is this a problem? Can i mate my front half with his rear half?
Also, im getting a SYE as part of the deal. Whats the best driveshaft to go with? Zack Last edited by YJJPWrangler; 10-24-2005 at 02:35 PM. |
Moderator
the 94 will have the incorrect input shaft for your 87 tranny. You should be able to swap your input shaft to the 94 t-case. The vacuum switch will most likely be able to be unscrewed from the 87 case and screwed onto the 94 case. That vacuum switch only powers your front axle disconnect anyway. In theory you should remove the vacuum from that axle anyway and either build a cable-lock setup, or install TJ shafts (or swap that axle out completely).
edit: for driveshaft, there are two major sponsors on this board... JE Reel and High-Angle. You could of course always go to a local driveline shop as well.
Check out our new Team Ape Eater Racing Like us on FaceBook KF5EQF Sniper Fab 4x4Oil SBwinVPS Custom Splice C2GFab Last edited by apeters89; 10-24-2005 at 03:02 PM. |
why would the xcase from the 94 have a different input shaft? Also I'm not really technical on trans cases. Is the input shaft the shaft that goes into the transmission? Also if i did have to switch input shafts...how much is one?
Zack Last edited by YJJPWrangler; 10-24-2005 at 08:44 PM. |
#4 (permalink) | |
Moderator
Check out our new Team Ape Eater Racing Like us on FaceBook KF5EQF Sniper Fab 4x4Oil SBwinVPS Custom Splice C2GFab |
your back half should fit
when swaping the input shaft and planatary gearset, you might have an issue with the input bearing. here is what i went thru to put a 1997 TJ case in a 1992 XJ http://www.opiebennett.com/images/Je...2015/np231.htm
Bryan 'Opie' Bennett JV Rally Post #175 Tellico Rally post #531 |
ok thanx man...i think we will tear it apart on wed...i really don't want to tear both of them apart and mate them together...so i should just change the input shaft right? (sorry, i need confirmation, its my dd and i need to get it back on the road) Thanx again
Zack |
the case from the 87 wrangler is not a np231 it is a np207. just so you know.
For whosoever shall call upon the name of the Lord shall be saved. ROMANS 10:13 For God so loved the world that He gave His only begotten Son, that whosoever believeth in Him should not perish, but have everlasting life. JOHN 3:16 |
#9 (permalink) | |
Moderator
ok, yet another question to ask... is your friends case from a 4cyl Jeep? If so it should actually bolt in, if not then you will need an input shaft from a 4 cyl Jeep 231.
#11 (permalink) | |
Moderator
I have no idea which input shaft your 6 cyl will have 'cause I never heard of an 87 with a 231. What tranny you got?
#12 (permalink) |
correct me if i'm wrong.....but wasn't the yj the first jeep of the chrysler era?
therefore no amc.
#14 (permalink) |
the tag says NP231 AMC not lying
and the YJ was the first model made from Daimler..i have the Peugot manual tranny, the input shaft on mine is 21 spline...I called Advance Adapters and they said it would work if the serial numbers were the same on the x cases. Zack Last edited by YJJPWrangler; 10-25-2005 at 08:02 PM. |
#18 (permalink) | |
Moderator
