#1 (permalink) | |
Who Has Pretzled a YJ Tie Rod?
Who has pretzled a factory yj tie rod? Are they solid steel from the factory? I'm running cross over steering so my drag link doesn't mount to the tie rod and i don't really need my steering stablizer. It's a not really possible to sleve so i'm thinking maybe angle iron. How often do they actually bend? We have a lot of trees and stumps but very few rocks up here. Anybody destroy an end?
I pretzled my drag link that was mounted way up high so i ended up sleveing it and throwing a spare in the trail box. Now i just need to beef up my tie rod so i have some beefy steering.
Lost
Member # 6426
I've bent 2 stock tie rods and yes, they are solid. Was able to keep wheeling on both of them but replaced before spending time on the road. Have literally pretzeled a drag link.
AS long as you're not running Hydro assist, I'd just stick with the stocker. Once you bend it up, go to a DOM or solid bar tie rod, especially if you're high steer on the drag link.
Couple of YJ's without leafs. |
Member # 20224
I have a PILE of bent YJ tie rods. Never took out an end though. I've swaped to a front D44 and went with real hi steer from Sky Manufacturing and aint had a problem since
Timbercrawler 89 YJ on 36's, 2.5L, Atlas4.3, D44 FR & RR, ARB and Detriot |
Member # 54600
i hade my draglink drilled and taped to 3/4 NF and the threads wore. i caught it before the heim pulled out, but it could have been bad. for drilling and taping tube, remember the threads are not as strong as an insert or a nut.
remember your buddy's cj5 after he ran up that tree? his draglink heim pulled out. -bildo
Wheel it to break it to fix it to wheel it. 84 [COLOR="Red"]C[/COLOR][COLOR="White"]J[/COLOR][COLOR="Blue"]7[/COLOR], Runs on alcohol ([COLOR="Red"]Old Mil[/COLOR]). 1984, 7, 100", 38s, 44s, 5.38s, 350, 465, 300, 92:1 |
#10 (permalink) | |
Member # 4375
I ran the same 1 1/4" .250 wall tie rod in JV for two seasons with ram assist and it's still good to go. In the same period, we helped swap out several bent smaller tie-rods on both YJ's and TJ's. The only other TR that was as durable was the solid one in the Currie HD steering set-up. We've yet to take one of those out and there's at least 6 sets of it out there on a steady basis. |
