BORED tb WHISTLES - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-25-2005, 08:44 PM   #1 (permalink)
Member # 55605
BORED tb WHISTLES
like the title says, I bored my throttle body out, and now it whistles ALL the time! Really loud too. any suggestions?
mtnbkrmatt is offline   Reply With Quote
Old 10-25-2005, 10:02 PM   #2 (permalink)
Member # 35220
suckin air sound
I have the bored t body also, but I think it was the helix power spacer I added that makes the sound. Mine is somewhat annoying also. I was told the spacer is not a bad add on but the helix part of it might be more of a gimmick. I thought about boring the helix part out of the spacer to see if that gets rid of the noise?
Someone else told me that the same set up with a closed air box might not make the noise. Mine is an open air filiment front and sides.
RiponWrangler is offline   Reply With Quote
Old 10-26-2005, 08:12 AM   #3 (permalink)
Member # 43184
Bore the intake inlet to match, and the spacer if you have one. If everything is bored to match it will flow better, and shouldnt whistle.
bnine is offline   Reply With Quote
Old 10-26-2005, 08:22 AM   #4 (permalink)
Member # 10411
Send a message via AIM to Spike5421
my stock TB whistles from about 2200rpm to 3000rpms at least
82 Cj7 (SOLD)
'04 4wd Taco, S/C, Allpro 3.5", 4.88 gears, ARB bumper, Warn, rocker guards.
Spike5421 is offline   Reply With Quote
Old 10-26-2005, 09:12 AM   #5 (permalink)
XJ_ranger's Avatar
Member # 31848
Send a message via AIM to XJ_ranger
Talking
turn up the radio
Bryan 'Opie' Bennett
JV Rally Post #175 Tellico Rally post #531
Originally Posted by asp87 View Post
I think our friend GreatWhiteXJ is forgetting a zero in his pulled-from-rectume tolerance. That's the only way it could possibly make sense. If that's the case, a refresher of 4th grade math is in order.
XJ_ranger is offline   Reply With Quote
Old 10-26-2005, 09:30 AM   #6 (permalink)
Member # 23574
Send a message via AIM to sintax
this is a known issue with bored TB's. Everyone one i've seen on a 4.0 has done it.
sintax is offline   Reply With Quote
Old 10-26-2005, 09:55 AM   #7 (permalink)
00pumpkin's Avatar
Member # 38716
Mine does it, but i like it................
America is all about Speed. Hot, Nasty, Badass Speed......
00pumpkin is offline   Reply With Quote
Old 10-26-2005, 06:46 PM   #8 (permalink)
Member # 8601
If you were bored you'd probably whistle too.
Root Moose is offline   Reply With Quote
