Jeep yj swap to full chevy axles questions
I have a 89 jeep yj. All the suspension is stock. I just got the axles out of a 3/4 ton 71 chevy. these axles were leaf spring.I believe that the axles are a 44 in front and a dana 60 in rear.I want to put the axles under my jeep. I have a few questions.
first, the front axle drop is on the passenger side on the chevy, and on the driver on the jeep. I heard there is a part that you can get to conv this. I dont know the name or if this is even a good option. Keep in mind these axles are free and have been geared and locked in the rear. second, in doing this is there any secret parts that i will come across in the project? As in leaf spring mounting. doing this will give me spring over, do i need to make long brake lines, drop pitman arm? things like this. When i take off the parts from the chevy, should i take anything else, like springs shocks...so on. I am also getting the transfer case and would like to put it in too. It is the 205 transfer case. is there any problems with this since the jeep already has a zz4 chevy small block. I know that i will need new drivelines. thank you Dannie |
Member # 30627
i wouldnt waste the money on a chevy 44 front. unless you plan to turn the knuckles to fix the pinon angle problem then IMO its not worth it. save your money and find a ford HP44.
i got stuff. |
El Presidente
Member # 38540
I smell some BullShit!!!.
TTC 2013 ! ! ! - THANKS FOR THE SUPPORT EVERYONE ! ! ! WWW.GLOBALOFFROADSUPPLY.COM *ROCK BRAWLERS* So-Cal www.RockBrawlers.com Fifth annual SoCal Off-Road Truck Show . Coming 2013 . www.OffRoadTruckShow.com |
I am definately not an expert on SOA's, but I wouldn't attempt to do what you are mentioning. What I would consider doing is taking the free stuff you got, sell it comlete, or part it out. Keeping the lockers if you wanted to. No you don't want to keep the springs.
Then follow YjTim's opinion and get Ford axles. The general opinion is that Ford F250 or F350 D44's or D60's from the years 78-79 are already the correct width, and damn near direct bolt ins for YJ's. The perches are 1/4" off. In addition they are drivers side drop. A ford NP205 transfer case is also the way to go. If you don't want to mess with ford stuff you can use Jeep Grand Wagoneer D44's, make sure it doesn't have the vaccume disconnect, they are generally the correct width. They came in narrow track, and wide track. The added bonus is the rear axles are already SOA. You will only have to convert the front axle. Yes you will need longer brake lines, longer drive shafts, definately a slip yoke eliminator kit for your NP231 or TCase if it has a slip yoke. Longer shocks. and the list goes on. There is a ton of info on the Board about SOA's for YJ's. Use the search option and SOA and YJ for keywords to start. You can also check out this site http://www.jedi.com/obiwan/jeep/soa.html I am doing an SOA on my YJ soon, and have been researching it for quite a while. No matter which route you take you will want to ge ahold of a welder ( or a friend with a welder) a grinder (to remove all of the brackets that arn't necessary), and several other fab tools to do the job. Look into an SOA kit like the one from Rubicon Express for the new spring perches, and other doo dads. Most imortantly don't forget the steering. The pitman arm is the catch. If you SOA the existing axles, you can get a used ZJ pitman arm it is roughly the correct drop. If you are using the steering linkages from different axles like the 60 you will need to work that one out. All in all read up on what people have to say about the SOA on this board, extremely helpful. Good luck
Is:92 YJ 4.0 AX15 NP231 D30 D35 Will Be: 92 YJ 4.0 NP435 NP205 D60 14 bolt SOA waggy spr. [URL]http://www.rawsoftware.com/YJ-Mule/[/URL] Last edited by yj-mule; 10-26-2005 at 01:47 AM. |
#5 (permalink) | |
my situation is similar to this, except my free axles are both 10 bolts w/4.88 gears and detroits in both. the rear also has a c-clip elim kit with it. will these work with minimal fab? if not what fab is involved. i need to get rid of the junk d30 and d35 that is in it already. i am retaining the factory 258 i6 and am going to swap in a np435/d300 tranny t-case combo.
For whosoever shall call upon the name of the Lord shall be saved. ROMANS 10:13 For God so loved the world that He gave His only begotten Son, that whosoever believeth in Him should not perish, but have everlasting life. JOHN 3:16 |
#6 (permalink) | |
Member # 6340
Location: Telluride CO, within site of of Black Bear Pass
Search here there is a ton of spring over stuff.
You can swap T-cases to run a Dana 300 and you would be ok with the Cheavy axles.
Marc In what appears to have been an understatement, the plant operator described the situation at the Number 4 reactor as "not so good." Super conversion calculator website Love and kisses, Zaphod.. |
Dabbler
I ran the same axles-good up to about a 35" tire with moderate wheeling. You need to either outboard your front springs-and just move your rear perches-OR cut into the front differential to add a new perch (I have done this myself and seen it done twice). Run a chevy tranny and tcase and you will be all set. Its that simple. And when you find that dana 60 you always wanted-it it another easy swap.
I kept my stock steering gearbox. You can either steer off the tierod or do a high steer converion and steer off the pass knuckle. Loose the boomerang steering-and keep the Jeep "style" gearbox set-up. I would reccomend a nice flat milled hiigh steer-passengers side knuckle and run your draglink and tierod off it-paired with a drivers side high steer arm as well. Your stock front driveshaft will probably still work-your rear shaft will have to put cut-and you should look at going to a Double Cardan Joint and adjusting your rear pinion ange to match your driveshaft angle (Good write up in the tech section by BillaVista) I use a modified YJ spring pack front and rear with an extra main leaf to prevent spring wrap. |
