wheel spacers - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-25-2005, 01:10 PM   #1 (permalink)
Member # 62664
wheel spacers
Does anyone run wheel spacers are their front end only? I need some extra clearance on the front and might as well save some bucks if I can.
2001 TJ, 4.0L Auto
4.88 gears, Ox locked, Ramsey REP 8.5
35" boggers
turbine99 is offline   Reply With Quote
Old 12-26-2005, 07:36 PM   #2 (permalink)
Member # 21815
I have run spidertrax spacers http://www.spidertrax.com/s.nl/sc.2/category.4/.f for a couple of years with no problems, and yeah, you can run them in the front only. In some cases it can actually improve handling. They will cause bearings to wear somewhat faster than normal.
resqme is offline   Reply With Quote
Old 12-26-2005, 08:10 PM   #3 (permalink)
Top Shelf
Tfab's Avatar
Member # 41032
I would rather buy new wheels with less back spacing than run wheel spacers. I wider front track width is good for wheelin it help you get around things. If you do run the spacers take off you front wheels from time to time and check you torgue on the spacers.
TRENT FABRICATION
www.trentfabrication.com
775-358-5337
Tfab is offline   Reply With Quote
Old 01-14-2006, 09:56 PM   #4 (permalink)
Joker2669's Avatar
Member # 47268
Send a message via AIM to Joker2669 Send a message via MSN to Joker2669 Send a message via Yahoo to Joker2669
yeah, does anyone have any pros and cons on wheel spacers? I'm thinkin they'd be a nice cheap mod to get a more agressive stance. and if I want to put some fat 12.50s on my XJ with these spacers, am i going to need to get extended flares?
Man became great through struggle - Show no compassion. Annihilate your enemies
'95 XJ - current trail rig, future tow rig) 33X12.5 SS'ers on 4.5RE Superflex, no sway, TNT Front Bumper, Cast Iron Rear
'87 Sami Stock (want to run 35's on a lift - future Trail Rig)
Joker2669 is offline   Reply With Quote
Old 01-15-2006, 06:23 AM   #5 (permalink)
Member # 18418
I've seen a few run them at Supercrawl this last year. Since my wheelin is not as xtreme that gets my vote.
jadedjeepster is offline   Reply With Quote
Old 01-15-2006, 07:44 AM   #6 (permalink)
Pat98TJ's Avatar
Member # 23629
Send a message via AIM to Pat98TJ
Wheel spacers are great. I run them with 42" tires. More stability, less tire rub.
Get them here in 1.25" or 1.5":
http://www.offroadoverstock.com/stor...rows=10&afid=&
The best deals are at [URL=www.offroadoverstock.com][SIZE=4][COLOR=Blue][B][FONT=Impact][FONT=Tahoma][FONT=Comic Sans MS][COLOR=Red]Offroad[/COLOR]Overstock.com[/FONT][/FONT][/FONT][/B][/COLOR][/SIZE][/URL]
Pat98TJ is offline   Reply With Quote
Old 01-15-2006, 08:47 AM   #7 (permalink)
Member # 15386
You'll want to put extended arms to get those big tires away from the back of the wheel well. The more you space it out, the further back the tires swing under the fenders!
Jim Blair, Seattle, WA
Build that Jeep boys, cuz it ain't gonna build itself!
carnuck is offline   Reply With Quote
Old 01-15-2006, 11:02 AM   #8 (permalink)
Member # 14004
I run front spacers. Having a rear about 3" narrower helps with the turning radius off road.
That said, spacers do cause the tire to swing through more of an arc, so turning is harder if you aren't moving and the tires might hit the fender as has been mentioned.
82 CJ7 - TBI 304/T18a/D300/44/70/4.88/40's
87 Samurai - GSX carbs/16V 1.6/GRS-II/linked rear/31's
Kreep is offline   Reply With Quote
Old 01-15-2006, 11:39 AM   #9 (permalink)
"All Whee Drive!"
MochaMike's Avatar
Member # 6450
Spacers work in the right circumstances.
You need to be a little more specific:
What axles do you have?
Are you keeping the 35" boggers? Are they 12.50s?
The further out you go with spacers, the more force/pressure you apply to the studs, spindles, knuckles, bearings etc...
Wheel size matters as well....
I know several guys who have 1" or 1.5" front spacers on Waggy D44 front axles. This gives them width to run a C&C 14 bolt rear.
Defintely monitor the lug nut torque settings...
Check them often....
I think I read about 2-3 people who lost wheels on various BBs because they loosened up & sheared off..
50yo IH Scout Parts
WeBilt 4x4
Originally Posted by RustoleumWhite View Post
Binder Planet is the Church, or Community Center, Pirate is the Bar. You'll get good tech at both places, but here you have to take the shit with the good stuff.
MochaMike is offline   Reply With Quote
