late 70's cherokee chief?
I am interested in swapping out the 727/am208 tranny/t-case combo from a late 70's cherokee chief into my 87yj. will the steering column from the cherokee fit my jeep? it is tilt steering btw.
For whosoever shall call upon the name of the Lord shall be saved. ROMANS 10:13 For God so loved the world that He gave His only begotten Son, that whosoever believeth in Him should not perish, but have everlasting life. JOHN 3:16 |
bttt
ttt
Member # 3845
just some fyi here no flaming intended! if a fsj had a tf727 its 80 or newer...
and most column's in that era were chevy tilt column's ![]() but it should fit,maybe some minor mods as posted before!
77 cherokee,360/t400/d300,d60/14 bolt disc's,5.13's,42" \../. rockers .\../ #326..79 jtruck |
what would it have if it were not a 727? it is a am208 though? i crawled under it and looked at the tag. on the column i can tell that mine has the bright light switch on the turn signal stick. the cherokee has it on the floor. is this a major mod?
#7 (permalink) | |
Member # 38459
Best way to tell is find the tag in the transfer case and see what it says. Remember, CJ7s with an auto had the QT case so it'd fit fine. |
Member # 360
If it is a stock, late '70s Cherokee with an automatic, it will have either the TH-400 and a Quadratrac transfer case or the TH-400 and a Dana 20 transfer case. The rear axle for the Quadratrac version will have the pinion offset to the passenger side several inches as the rear output of the t-case is aligned with the front output. The rear axle for the Dana 20 version will have the pinion pretty much centered as the rear output of the t-case is aligned with the mainshaft of the transmission.
Jim Kyser 1946 Willys CJ-2A |
i was told it was a 79 cherokee chief. it is an auto and the t-caase tag says am208.
Member # 360
What side is the front pumkin on, driver's or passenger's? They switched to the 727/208 combo in 1980 and at the same time moved the front pumkin to the driver's side.
drivers
#12 (permalink) |
Member # 23066
The 400 was never offered with the dana 20, only the QT case.
If the Cherokee is driver side drop its a 80 or newer. 79 and older were passenger drop.
09 JK unlimited Rubicon 07 2500 CTD Ram 02 Grand Cherokee 79 Cherokee WT 360/T18/Dana 20 ] |
#13 (permalink) |
Member # 15386
The TH400 was offered with D20 from '63 up till '72 (Starting with the J100 and J300 which became Wagoneer and Jtruck respectively and evolved into their own nameplates @ '65). In '73 it became an extra option along with the Quadratrac till '75 and then it only became available with std trans till '79.
The body may be pre '79, but someone could have changed the drivetrain from a newer one (with the rotted frame problem that '80 up had in salty areas) along with the axles. I almost put a '84 GW body on a '76 frame so I know how "easy" it is. (3 days work, then I found a J truck instead and scrapped the other project)
Jim Blair, Seattle, WA Build that Jeep boys, cuz it ain't gonna build itself! |
#14 (permalink) | |
Member # 38459
Anyways, if its a driver's-side drop front axle, lockout hubs and a AM208 t-case IT IS NOT A 79. The 727/208 combo = what you have - is fairly long. Take a measuring tape and make sure it'll fit. Might make your driveshafts VERRRY short. Next ya gotta adapt it to your motor. Or were you going to use the motor from the Chief? What motor is in the YJ? |
#15 (permalink) |
Archimedean
i have used wag tilt column in CJ tub, you have to change the tin collar at the lower end of the column.
wiring is just wiring, you can move the hi - lo switch.. i have owned fsj's with th400 QT and 400 / d20 and yes, the 727 208 would be waaaaay long in a yj... |
#16 (permalink) |
Member # 15386
You could go with an IH 6 cyl 727 and D20 setup. It's an AMC 6 in the IH (The V8 ones are different)
Jim Blair, Seattle, WA Build that Jeep boys, cuz it ain't gonna build itself! Last edited by carnuck; 01-17-2006 at 07:51 PM. |
