Mile Marker Winch - pros and cons - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-20-2006, 03:56 PM   #1 (permalink)
Member # 57159
Finally going to buy a new winch. Mile Marker has a low price but what should I know good or bad? Firsthand experience preferred.
andy 1333 is offline   Reply With Quote
Old 02-20-2006, 04:10 PM   #2 (permalink)
Member # 51586
This question is about as hardcore as a late night HBO movie; use the search button, dillweed.
Roscoe P. Coltrane is offline   Reply With Quote
Old 02-20-2006, 11:16 PM   #3 (permalink)
Member # 11973
Send a message via ICQ to Murfman Send a message via Yahoo to Murfman
I have a MM winch and there is nothing wrong with it. It is just a little slower than a Warn or Ramsey.
Only in a Jeep
Murfman is offline   Reply With Quote
Old 02-21-2006, 02:53 AM   #4 (permalink)
Life on the Darkside
Brink_'s Avatar
Member # 63901
That's why it's he put it in the newbie section asshat
Don't fawkin flame just to get your post count up and try to fit in
Brink_ is offline   Reply With Quote
Old 02-21-2006, 05:14 AM   #5 (permalink)
kris1351's Avatar
Member # 40704
Sheesh trying to flame someone in the right section with a username that isn't even spelled right.
Rosco P. Coltrane - http://en.wikipedia.org/wiki/Sheriff_Roscoe_P._Coltrane
Kris
Buy it, use it, break it, fix it, trash it, change it, melt - upgrade it
http://www.myjeepsite.com - Free Pic Hosting & Blogs
http://www.ncserv.com - Premier Web Hosting Solutions
kris1351 is offline   Reply With Quote
Old 02-21-2006, 06:08 AM   #6 (permalink)
Member # 51586
It was originally posted in the Hardcore forum, fawktards
Old 02-21-2006, 06:48 AM   #7 (permalink)
Member # 13176
Had the basic MM 8,000 lb electric for a few years, right after they fist came out. It was slow, but never gave me a bit of trouble, even when pulling in deep sand. I liked its line-holding brake, too. It didn't wind-down when you stopped pulling - it would stop, immediately. I'd have no problem buying another, but I'm now interested in their 9,500 lb integrated solenoid model.
Brian Lucero
SubCulture New Mexico
www.subcultureworldwyd.net
SubCultureNM is offline   Reply With Quote
Old 02-21-2006, 07:06 AM   #8 (permalink)
Cue-Ball's Avatar
Member # 17311
Hardcore Forum or not, The search is down for a while so Lance can upgrade. So shut up.
Andy, are you looking at the MM hydrolic winches or the Electric ones. The pros and cons differ depending on what we are comparing here.
Nex Pro Evinco "Death Before Defeat"
Cue-Ball is online now   Reply With Quote
Old 02-21-2006, 09:09 AM   #9 (permalink)
Member # 38563
I have a hydro MM right now which pulls like a mule and has pretty decent line speed when in high range. The only thing that sucks is that you cannot turn your wheels while winching. The steering box gets all the pressure and the winch stops pulling. When you release the steering wheel, the winch begins to pull again. Other than that, its the balls. I had an 8K electric MM which pulled like a mule but as slow as one too. Plus the clutch lever and remote control was very cheap plastic. You get what you pay for. If you are a weekend wheeler that would only use it once and a while, it is a good value. For a regular crawler or mud bogger, go with a tried and true Warn.
95' 4Runner with 5VZ engine WTB...winch bumper
84' M1031 CUCV 37's, 8kW gen
Pietro is offline   Reply With Quote
Old 02-21-2006, 10:02 AM   #10 (permalink)
Schmozilla's Avatar
Member # 38562
Send a message via AIM to Schmozilla
n00bs flamin' n00bs
Schmozilla is offline   Reply With Quote
Old 02-21-2006, 11:15 AM   #11 (permalink)
jesster's Avatar
Member # 49468
I have a WARN M8000 on my Jeep. A couple of friends who have the MileMarker 12000 electric winches on their YJ's and one who has a MileMarker PE8000 on an XJ. One of the 12000's has had a few problems (bad solenoids and a broken winch mount which caused housing to crack and grenaded the internals), but the MM guys are taking it back for an exchange, so that says something about their customer service. The only problems with the MM 12000 that I can see are that the 125 ft of 3/8 cable is too much for the drum wich causes problems if you don't spool it onto the winch perfectly and second that the MileMarker 12000 is very slow compared to my Warn M8000 in most situations. The MileMarker PE8000 has worked like a charm for my one friend so far, but I wouldn't recommend it for someone who needs to winch alot, as it is has a permanent magnet motor, is very slow and has a weird cheap looking clutch release lever.
Whatever winch that you decide on, I would try to stick with winches that have a Series Wound motor as they should last longer. Stay away from cheaper winches with the permanent magnet motors, unless you are only going to use the winch once or twice a year.
jesster is offline   Reply With Quote
Old 02-21-2006, 11:29 AM   #12 (permalink)
Member # 18462
pro-cheap
con-slow, you can easily outdrive the winch, kinking the cable
I wheel with two guys who have MM8000s. Both still going strong after ~4years. However, one does smoke a little after hard long pulls, but never has failed him.
sixditch is offline   Reply With Quote
Old 02-21-2006, 12:26 PM   #13 (permalink)
4x4not's Avatar
Member # 27342
Send a message via AIM to 4x4not Send a message via Skype™ to 4x4not
Guess I'll throw my opinion in. I got the PE8000 a couple months ago because I'm a cheapass, and so far I have used it half a dozen times and it has worked flawlessly. Very slow, but it pulls good. 90% of the time I'm using the winch on someone else, so why the hell should I spend $1000 to pull YOUR ASS OUT? I don't do mud, so my winching is usually to get myself or someone else a couple feet when they get hung up on the rocks.
When I finally do my real build, THEN I'll probably get a nice fast Warn.
Unwheeled
4x4not is offline   Reply With Quote
Old 02-21-2006, 12:39 PM   #14 (permalink)
Member # 47848
I'm happy with my MME9000. It is slow but I don't use it a lot. I bought a snatch block from ewinches. This is because I drive full size. Knock on wood: It has got me out of everything I have put it through. MM Customer Service is good as well. I had to call a couple of time regarding a custom install.
[QUOTE]Yep, no sissy poser no use other than look good pansy crap on my truck! Jason Payne
[/QUOTE]
1999 4Runner
4x4mike is offline   Reply With Quote
Old 02-21-2006, 01:22 PM   #15 (permalink)
butch6924's Avatar
Member # 29636
Send a message via Yahoo to butch6924
The MM PE8000 that I've used is pretty torquey but as stated, really slow. If you're just wanting one to slap on the front of a smallish Jeep for infrequent use, I would confidently recommend that choice.
butch6924 is offline   Reply With Quote
Old 02-21-2006, 02:23 PM   #16 (permalink)
phattdraggon's Avatar
Member # 50975
Pro Price, Con Inferior motor design (at least on the lower end non hydraulic units).
Series wound motors are going to be by far, the best. fastest and most reliable being the key.
phattdraggon is offline   Reply With Quote
Old 02-22-2006, 04:54 PM   #17 (permalink)
Member # 24475
Send a message via ICQ to JeffsJeep04 Send a message via AIM to JeffsJeep04
Pro: Cheap, looks like a winch
Con: only warrantee'd for the first break, slow, supports the chinese
2000 WJ Limited 4.7 quadradrive
JeffsJeep04 is offline   Reply With Quote
Old 02-22-2006, 06:17 PM   #18 (permalink)
Member # 44579
My 9000 works great but will not make a full line length pull before overheating and stopping. Other then that it works geat with my XJ.
[b][ ] [u]l l l l l l l[/u] [ ][/b]Save your money for gears and swampers then save money on your lift by cutting out your fenders.
TACH329 is offline   Reply With Quote
Old 02-24-2006, 11:58 PM   #19 (permalink)
Member # 65851
Sounds like you plumbed it wrong it should go from the solenoid to the winch then from the winch to the steering box them return to pump, when not active should only go from pump to solenoid to steering box...
Mark32725 is offline   Reply With Quote
Old 02-25-2006, 01:25 AM   #20 (permalink)
Banned
Member # 47849
I agree. My brother had one of his jeep. They are a little slower but they are hold their own. My brothers had been through hell and back and kept going. He liked the winch but sold it because he was wheeling more and wanted something faster with a bigger following (warn)..
SuckyJeep is offline   Reply With Quote
Old 02-25-2006, 05:43 AM   #21 (permalink)
BillR's Avatar
Member # 4798
Send a message via MSN to BillR
I have an MM SE12000 on mine. It has a series wound motor, and pulls less amps at an 8000# pull than ANY other 9000# winch.I agree with the previous poster that MM used too much 3/8" cable for the drum size. I swapped mine out for 100" of 5/16" Amsteel rope. Problem solved!
Mine's worked flawlessly every time I've hit the button, and I'm not at all concerned that it's a little slower than other winches.
'01 TJ, Atlas II, "Super" 8.8, Detroit, HP30, OX, Clayton LAs...
BillR is offline   Reply With Quote
Old 02-25-2006, 08:21 AM   #22 (permalink)
Brink_'s Avatar
Member # 63901
My 9500 is a little slower than a comparable Warn. And overall it just feels flimsy. A little too much plastic to it for my liking. That said it's never let me down even under long pulls and heavy extractions.
Old 02-25-2006, 09:42 AM   #23 (permalink)
Member # 34005
What did you guy pay for your Milemarker winches?
buckallred is offline   Reply With Quote
Old 02-25-2006, 09:48 AM   #24 (permalink)
Brink_'s Avatar
Member # 63901
Think it was about $600 canadian for the 9500 up here
Old 02-25-2006, 09:50 AM   #25 (permalink)
Member # 47749
I'll add one more Con... made in China... its a matter of choise, if thas a big deal to ya or not.
WoRM
Rockworm is offline   Reply With Quote
