72 cj5 axle ratio - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-20-2006, 07:00 PM   #1 (permalink)
beat cj's Avatar
Member # 64937
72 cj5 axle ratio
I have a 72 Cj5 that i have been reassembling for almost a year now. I finally got it running and drove it. It was ungodly high geared. So i jacked up the rear of the jeep and marked the driveshaft to count rotations....My brother turned the wheel a revolution and i counted the shaft rotation. I only came up with about 1.8 turns. This is way low, i never even saw a ring and pinion set this low( numerically). Has anybody heard of a ratio used < 2:1 in the axle?? Any info would help. thanks
beat cj is offline   Reply With Quote
Old 02-20-2006, 07:17 PM   #2 (permalink)
4x401cj's Avatar
Member # 37244
Pull the rear cover and read the #`s on the ring gear. Most of the `72-`75 cj`s I`ve delt with had 3.73`s. That would be my guess for yours also.
4x401cj is offline   Reply With Quote
Old 02-20-2006, 07:31 PM   #3 (permalink)
beat cj's Avatar
Member # 64937
yes thats my next step...i am at college and i only get home once in a while so next time i will do that.
Old 02-21-2006, 06:39 AM   #4 (permalink)
Haggar's Avatar
Member # 11570
If you only turned one wheel, and the other stayed put, it rotates the driveshaft only 1/2 the number of times.
3.73 gears / 2 = 1.865..
Most of the 72-75 Bastard years had 3.73 gears, some of the 6 cyls had 4.27s. Those were the only gears available.
Both my 75s had 3.73s, one was a 304, one was a 232.
Haggar is offline   Reply With Quote
Old 02-21-2006, 07:56 AM   #5 (permalink)
piratebuggy's Avatar
Member # 53597
Sometimes it's easier to rotate the wheel 10 times to get a better read on the exact ratio.
78 Jeep CJ-5 304 ---setting off car alarms with extreme prejudice.......
out cali style!!!!!!
piratebuggy is offline   Reply With Quote
Old 02-21-2006, 12:26 PM   #6 (permalink)
Member # 40958
Add 4.10s to that
Chato is offline   Reply With Quote
Old 02-21-2006, 07:11 PM   #7 (permalink)
Member # 66700
Haggar, please tell me more about how only turning 1 wheel rotates the drive shaft 1/2 #times. I guess I dont fully understand how differential / drive shaft works. thanks.
pharmvet is offline   Reply With Quote
Old 02-21-2006, 08:55 PM   #8 (permalink)
beat cj's Avatar
Member # 64937
hmm your explanation solves the problem 1.8 mystery but I never heard of the driveshaft rotating half as much by only turning one wheel....interesting
Old 02-21-2006, 09:29 PM   #9 (permalink)
KiGrind's Avatar
Member # 66647
HERE!
http://www.off-road.com/jeep/tech/axle/amc20.html
This page covers all the axels in Jeeps and gives ratios and how to ID them and such.
Helped me!! Turns out I've got an AMC20 3.54 Trak-Lok (Wasn't planningon a locker anyways :-/ not in this weak poo)
79 CJ-7
95 ZJ
KiGrind is offline   Reply With Quote
Old 02-22-2006, 08:31 AM   #10 (permalink)
Member # 53597
Of course if you have a limited slip you wouldn't be able to rotate just one wheel.My axle code comes up as a 3.54 Trak-Lok but it can turn one wheel,I was told somebody "went through" the rear axle before I bought it.My question is-to save me having to pull the cover off-is the Trak-Lok a clutch type or torque sensing type of limited slip?(anyone?)The driveshaft only turns half times do to the differential action of the spider gears in an open type diff.
Old 02-22-2006, 08:48 AM   #11 (permalink)
KiGrind's Avatar
Member # 66647
I think its clutch and mine does the same thing, was told they might need replacing.
I'll do it when I replace the bearings and seals.. What a fun project that will be for me.
79 CJ-7
95 ZJ
