69 Buick 350 from a 69 J2000 what to put in CJ7 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-01-2006, 06:55 AM   #1 (permalink)
Mud Dragon's Avatar
Member # 67479
I have a 1969 J2000 with a 350 Buick and stand trans and transfer case. I want to put the drive tran in my Cj7. It came with a 304 and stick. I sold the 304 and spent the money on the buick. The buick holds oil pressure at 60 pounds and is 10 to 1 compression.
Mud Dragon is offline   Reply With Quote
Old 03-01-2006, 07:38 AM   #2 (permalink)
Low Range Drifter
JohnnyJ's Avatar
Member # 7903
Ok. Is there a question?
DEAK Racing #715 TREC B / Ultra 4 Mod Class Rig
Thanks to Drivetrain Specialists and PAC Racing Springs for your support
JohnnyJ is offline   Reply With Quote
Old 03-01-2006, 07:44 AM   #3 (permalink)
Mud Dragon's Avatar
Member # 67479
What's need to swap the buick 350 into my CJ7.
Old 03-01-2006, 07:54 AM   #4 (permalink)
LCAC_Man's Avatar
Member # 35307
New motor mounts, modified crossmember, new shifter, new drivelines, modified cooling system, trans cooler, oh and maybe a screwdriver would come in handy.
On the positive side, the buick 350 is an awesome engine.
Len Barron
72 Commando/LS2/4L65e/NP241
DRWHP60-ARB/14B-Detroit/4.56/H1's/37's
Bullnose Build in Progress
Stretched Bullnose
LCAC_Man is offline   Reply With Quote
Old 03-01-2006, 08:52 AM   #5 (permalink)
Mud Dragon's Avatar
Member # 67479
I spent alot of money when I rebuilt the Buick but it sounds bad A$$. 10 to 1 should move it throw the mudd... Hopefully better than my 304. I just got some 38inch boggers for her..[/IMG]
Old 03-01-2006, 09:02 AM   #6 (permalink)
piratebuggy's Avatar
Member # 53597
Somebody can correct me on this if I'm wrong -but I believe you should refer to the engine as a BOP 350(Buick Oldsmobile Pontiac). This would distinguish it from a SBC 350 (small block chevy) when you are talking to various companies for parts,adaptors,mounts ,etc. if that helps. I don't remember off hand if it requires a different mount set-up,but there is a difference in a lot of other parts.
78 Jeep CJ-5 304 ---setting off car alarms with extreme prejudice.......
out cali style!!!!!!
piratebuggy is offline   Reply With Quote
Old 03-01-2006, 10:46 AM   #7 (permalink)
Member # 360
The only thing BOP about it is the bellhousing bolt pattern. Other than that the Buick, Olds and Pontiac engines were each unique unto themselves. Some shared displacements, but there still wasn't any parts commonality.
Jim Kyser
1946 Willys CJ-2A
JimKyser is offline   Reply With Quote
Old 03-01-2006, 03:30 PM   #8 (permalink)
Member # 53597
OK-I'm a little confused by the J2000 thing-I thought that was a Pontiac car? And yeah-I knew about the bellhousing thing, but wasn't sure having never messed w/anything except Chevy stuff.
Old 03-01-2006, 03:46 PM   #9 (permalink)
Member # 55559
the J2000 is a fullsize jeep pickup.
mikesova is offline   Reply With Quote
Old 03-01-2006, 05:44 PM   #10 (permalink)
Member # 53597
My bad-learn something new everyday. I've seen the Buick V-6 in Jeep products before,but not the 350.
Old 03-01-2006, 07:08 PM   #11 (permalink)
Member # 62
I thought the late 60's jeeps had some odd ball 327?
At any rate if you have the full package engine/tranny/transfer case you just need to find a way to bolt it to the jeep.
Jeff Neves
NE-RokToy is offline   Reply With Quote
Old 03-02-2006, 10:06 AM   #12 (permalink)
Member # 12281
Yep, the AMC "Vigilante" 327. The Buick 350 was called the "Dauntless".
Hump is offline   Reply With Quote
Old 03-04-2006, 10:05 PM   #13 (permalink)
Member # 53597
I thought just the V-6 was the "dauntless". I do see the 350 and the 327 listed as possible engines in an old Chiltons I've got.Not much else on them,there were alot of engines available over the years in Jeeps.
