Member # 24612
what 8.8 to buy?
Is there any difference in the Ford 8.8 rearends. I found one out of a 91 Exploder for fifty dollars. It has drums and is stock. Would it be a good buy. Any options bad or good on these things?
Member # 30098
I would look at the threads on Jeeps Unlimited, TJ section. They have a FAQ on 8.8s that is pretty extensive.
However, most folks who want an 8.8 want the disc versions, especially since it helps if you ever break a c-clip axle. Not perfect, but better. You want to make sure the axle shafts are 31 spline as well...so check the JU thread.
[FONT=Arial]Feature Editor C4x4.com. Former owner of project This Old Scout. New owner of Project 'Blue Oval YJ', an 89 Wrangler with lots of potential! [url]http://www.c4x4.com/new_projects/yj/blue_oval_yj.html[/url] [/FONT] |
Member # 39045
http://www.jedi.com/obiwan/jeep/ford88.html
All Explorer axles 91-01 are 31 spline. 95 and up had disks.
Anthony |
Member # 30098
c-clip
Member # 64893
f-150 8.8 is 5x5.5. if it is an explorer axle it will be set up for spring under have 31spline shafts and be fairly easy to upgrade to disk brakes with junkyard parts. they are all c-clip and for $50 bucks you got a good deal.
Member # 68697
I hear the '91's have plastic diff covers on them. Regardless, even the later ones are very very thin almost tuna can thickness metal.
I did this to mine from a '98 on my shakedown run: Luckily even though it actually hit my ring gear there wasn't any physical damage. Part of this could be because the metal is so darn soft. I ended up going with this from Crane: BTW, I'm Mike and this is my first post..... so, Hey, good to be here... Mike Last edited by mingoglia; 03-06-2006 at 03:26 PM. |
Member # 53265
hold out for one out of a later model explorer. the disc brakes are a big plus. you'll spend more if you get one with drums and then cobble together the disc parts.
plus one from a 91 is likely to have a shit-ton of miles on it. got mine out of a 01 exploder with less than 60k miles on it for $200. complete.
TELLICO RALLY POST #264 |
#13 (permalink) |
Member # 40704
Mine came from a '96 Exploder 4x4 so it had discs and 4.10 gears from Ford. I am told some of the later models had the 4.10s in the 4x4 version and some had 3.73s. Definately worth looking for though.
Kris Buy it, use it, break it, fix it, trash it, change it, melt - upgrade it -------------------------------------- http://www.myjeepsite.com - Free Pic Hosting & Blogs http://www.ncserv.com - Premier Web Hosting Solutions |
#14 (permalink) |
Mine came from a 91, i only paid $200 canadian for it which is the going rate for them in my area, I went with drum because it was cheaper and in our area you only really go with a disc if your big into mud.
I don't really think that my 4 banger will have enough poop to blow up an 8.8's c-clips, and if it does i do carry spare shafts. With mine, I didn't really care what kinda klicks were on it, it gets cleaned up, re-geared and I even rebuilt the L/S tighter, so for the most part its brand new. So I think for $50 you got a really good deal. PS if your going to blow big money on a fancy diff cover, get one with a built in oil drain plug, I hate removing my diff cover to replace the oil.
4cyl YJ 33/12.5 BGF AT K/O's, RE4.5ED, AR 767's, Boomerangs, DT Shocks, What Swaybar? AA HD SYE,8.8/LS and 4.88's, HPD30 4.88's, 1750 KG's with all my junk. |
#15 (permalink) | |
Member # 68697
#16 (permalink) | |
Member # 13055
Got mine out of a 97 with low miles, for $120. Keep shopping! |
#19 (permalink) |
Member # 50099
summit also sales c clip eliminator kits, for added piece of mind, if you are going to tear into this to replace and repair items, it might be a good time to consider tossing a set in.
#20 (permalink) |
Member # 65809
try this web site .. http://car-part.com/
07 Harley Davidson FLHTC 131 inch 7 speed 06 F150 King Ranch super crew cab 4x4 77 Sanger v-drive |
#21 (permalink) |
Member # 25915
I bought mine out of a 98 with 4.10's for $79 complete with all the brake hardware. I have never heard the C clip being an issue - especially with the disk brake version. I actually preferred to get mine without the limited slip so I could install an Aussie locker.
#24 (permalink) | |
Besides all of that, on a disc brake 8.8 you've got calipers to perform the function. Let's be honest, can anyone cite a personal experience with an 8.8 shaft snapping? I'm sure they can but when you weigh that against how many 8.8 are going under Jeeps lately, I think you'll find the statistic pretty nill. |
