TJ pitman arm problem
Since I threw the 60-9 under the front of my 03' TJ Rubicon I have lost turning radius. My steering stops do not touch now. It is setup with a high steer and stock pitman arm. I think the lost is due to the lenght of the stock pitman arm. What options do I have with pitman arms that are longer to regain my radius, if not increase it. Stops touch when drag link is disco'd from arm. TIA.
-Erik |
Member # 40015
From looking at your setup you will lose steering only because your axle is wider.
![]() ![]() A Longer pitman arm should serve your turning radius back to where it was. Find a ford pitman arm out of the junkyard like I did or get one made from JB's 4x4 to fit your heim and exact lenght you need. I believe a stock pitman arm on a TJ is 5.5. I would suggest a length of 6.5. The one pictured is at 7 and is also perfect but the way I have the draglink and tierod setup the acutally cross eachother which is fine. Nice jeep by the way. I snagged a picture of it when you were in Sommerset,MD sitting on the side of the road. Spencer |
Waggy arm = flat ~7.0"
WJ arm is 1" drop ~6.75" if you need more drop just get a drop arm for a waggy
www.WILSONPERFORMANCE.com |
