Suspension ride Height/axle swap questions, PICS - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-01-2006, 12:30 PM   #1 (permalink)
Member # 40587
I'm gathering parts for a set of waggy D44 swap axles. I'm going sprung over with (i think at this point JC Whitney military wrap stock height springs) I will only be running 35s maybe 37s down the road. The WMS is 62" on the waggy axles. I have major concerns about ride height and low CoG. My current set up (see pics) is 35" tires, stock axles with slightly sagged/wheeled hard 3.5 inch SUA military wrap springs, 1" Bl for T-18 clearance and t-case clocking, and 1" shackle Lift in rear so military wrap doesn't hit frame. It looks good too with front lowered i think but thats unimportant really. It's also fitted with TJ flares. The clearance between the tires and the flares is about 6 inchs in front and 7 inchs in rear. Total height as it sits is 4.5 in the front, and 5.5 in the rear.
My concern is that if I go SOA I will be too high and tippy for 62" axles. I can’t run axles wider than this. Does anybody have an insight or opinions on this and whats everybody elses SOA rigs setup at? My preposed totals with all the lifts would be 6.5” in front and 7.5” in rear. Pics would also be appreciated.
Full side view, you can really see front is lower than rear here, I’m 6’3” and top of connecting tubing that connects front hoop is at top of my head.
Another view
last view
The Black Sheep is offline   Reply With Quote
Old 04-01-2006, 12:53 PM   #2 (permalink)
WA-HCRC's Avatar
Member # 39184
start hackin on that thing, whats your exuse, hell, its got a frame!
:goofball:
WA-HCRC is offline   Reply With Quote
Old 04-01-2006, 12:54 PM   #3 (permalink)
Doublewide engineer
kwrangln's Avatar
Member # 6971
Here's my last heep, soa, stock YJ springs, added main leaf, 35's. Sits about the same clearance as yours does now I guess, from the pics anyway. Add an inch for the body lift you have. Probably be pretty close.
I'm the "tack tack tack" welding nazi.
http://www.pirate4x4.com/forum/showp...&postcount=218
"I didn't mean to kill nobody ... I just meant to shoot the sonofabitch in the head. Him dying was between him and the Lord." R. L. Burnside
kwrangln is offline   Reply With Quote
Old 04-01-2006, 10:37 PM   #4 (permalink)
Member # 54975
Send a message via AIM to Plato2k5
on my 88 yj build i'm doing rite now i have 1.5 RE SOA 5leaf springs. Custome shackle reversal kit, stock shackle lenghts, i'll be adding a 1" body lift so i can clear 37"s with no prob. Here are some pics of it on 29" roll around tires
oh and the axles are dana 44 hp and ford 9" out of 78 ford fullsize
Plato2k5 is offline   Reply With Quote
Old 04-02-2006, 09:53 AM   #5 (permalink)
Member # 11973
Send a message via ICQ to Murfman Send a message via Yahoo to Murfman
I run SOA with 2.5" OME springs. My buddy was running 4" SUA and I was about 1.5" taller. I sit 36.5" at the bottom of the doors, this is also with a 2" body lift. you can run stock YJ springs SOA and you will not be much taller than you are now. You can also go full width axles and run deep back spacing wheels to bring the tires back under the fenders.
Only in a Jeep
Murfman is offline   Reply With Quote
Old 04-02-2006, 01:57 PM   #6 (permalink)
Member # 2095
IMO it'll be fine
'79CJ5,soa,d44/60,t18,d18w/Obrian 3.6low,5.13's,35x14.5SSR's
'02 Z71
CJ-Jeeper is offline   Reply With Quote
