throw out bearing question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-23-2006, 09:16 PM   #1 (permalink)
Member # 44063
Send a message via Yahoo to jeepdeepfreak
This is a newb like question so I'll post it here.
vehicle:1989 jeep cherokee,4.0,ax15 5speed external slave conversion,
Can someone tell me if the throwout bearing is in contact with the clutch fingers while ideling in neutral?I'm trying to diagnose a noise.....
jeepdeepfreak is offline   Reply With Quote Quick reply to this message
Old 04-23-2006, 11:23 PM   #2 (permalink)
Tfritz's Avatar
Member # 51449
Yes they are always in contact.
Tfritz is offline   Reply With Quote Quick reply to this message
Old 04-23-2006, 11:33 PM   #3 (permalink)
Member # 44063
so the t/o bearing rides againsts the clutch fingers even while in neutral?
I have a grinding/whining noise only while idleing in neutral...it goes away completely when I push the clutch in??I was inclined to think transmission input shaft bearing.....but have been told by a few peaple that it is probably the throw out bearing....
Old 04-24-2006, 04:02 AM   #4 (permalink)
Member # 65332
The throw out on my CJ is 1/16 off the fingers
fishotro is offline   Reply With Quote Quick reply to this message
Old 04-24-2006, 04:31 AM   #5 (permalink)
Member # 42803
I would venture to assume if it is only noticable in neutral it may be the input shaft bearing, as the throw-out is always in contact, but I duno.
ElPasoEric is offline   Reply With Quote Quick reply to this message
Old 04-24-2006, 06:09 AM   #6 (permalink)
Member # 1231
Most likely, I just had the same probelm/noise and pushing the clutch in made it go away. Replaced T/O bearing along with a clutch and the noise is gone. BTW, the T/O bearing looked like toast.
Curtis M.
Ridgecrest, CA
Weatherman is offline   Reply With Quote Quick reply to this message
Old 04-24-2006, 09:31 PM   #7 (permalink)
Member # 44063
The trans is a remanned unit from man-trans.com,the clutch is a new pro gold with all new componets....everything has less than 300 miles total so I'm at a loss.
Looks like I'll find out exactly what the culprit is when I get the motivation tear into the fawker!
thanks for the replies.
Old 05-01-2006, 09:35 PM   #8 (permalink)
Member # 18561
before you go and rip into it you should check to make sure your starter is properly engaging the flywheel and that it is tight...when i did my 5.0 swap i had a terrible noise coming from what i thought would be the throwout bearing turns out the starter as cocked and was rubbing the flywheel...when i pushed the clutch in it went away..i guess as the flywheel flexed it stopped rubbing or some shit..anyway i checked it by letting the jeep idle in neutral then get under there and try to wiggle the started back and forth...but before anything chock the wheels or put the e-brake on so nothin bad happens..good luck
jeepfreek383 is offline   Reply With Quote Quick reply to this message
