35's....37's.....big diff?? - Pirate4x4.Com : 4x4 and Off-Road Forum
View Poll Results: Will hold up or should I drop to 35's
Run it get alloys it will hold up 25 65.79%
drop to 35's You'll be better off 13 34.21%
Voters: 38. You may not vote on this poll
Old 04-29-2006, 04:31 PM   #1 (permalink)
Member # 25951
I have a hp d44 front,and a waggy d44 rear...they were in my Xj with 35's and they held up well...I beat on that thing pretty hard....
Now those axles are in my tj with 37 inch mtrs....Havent wheeled it yet. Alloys are in the plan but until then....
Am I screwed or will it hold up?
trailbuilt is offline   Reply With Quote
Old 04-29-2006, 04:44 PM   #2 (permalink)
Typical White Guy
Member # 9769
Just realize you're on the outer working limits of the stock parts and adjust your driving style accordingly; that's the best advice I can give.
________
Ipad Cases
Indyguy is offline   Reply With Quote
Old 04-29-2006, 04:53 PM   #3 (permalink)
sodaboyYJ's Avatar
Member # 17421
Send a message via Yahoo to sodaboyYJ
I ran Warn alloys and CTM in my old HP D44..... when the shit hits the fan, it hits hard!! When the outer shaft finally broke, the ball joints nuked too.... You're really pushing your luck on a D44, HP or otherwise.
BTW: Warn will not warranty failure when used with 'super u-joints'
'93 YJ, 5.0/C6/Atlas 4sp/ 38.5 SX's...D60's F&R with ARB's on coils
sodaboyYJ is offline   Reply With Quote
Old 05-02-2006, 09:45 AM   #4 (permalink)
Member # 26893
Send a message via AIM to Petti
running a waggy front and a TJ rear with moser shafts, and i have gotten on it pretty hard, run it yo uwill be fine, just know when to be locked, and when not......
lost front warn hub twice, (once was my fault, not fully ingaged)
3 driver side u-joints. (1 spicer, one junk, one the ears on my stub were blown out)
rear, i managed to split my CV on the rear shaft this past weekend in the driveway, made it all weekend wheeling....... go figure
2002 TJ 4.0L 5sp. D300 ARB'd D44 F/R 37" MTR/s
[QUOTE=Diesel Smoke;7969796]It takes two things to build a rig, money and time. Having alot of one means needing less of the other.[/QUOTE]
Petti is offline   Reply With Quote
Old 05-02-2006, 10:32 AM   #5 (permalink)
Member # 47730
YOU WILL BREAK THEM!!! run 35,s with superior shafts and super joints and you wont have any problum,s.
2nuts4u is offline   Reply With Quote
Old 05-02-2006, 11:39 AM   #6 (permalink)
4x4 Consultant
UGET IT's Avatar
Member # 227
Just got back from the Hammers with 37 MTR's D30 & D44 in a TJ. No problems with them. Running Alloys and 760's with full clips.
Dont overdrive them and you wont have a problem.
Method Motorsports
Follow Me Here: /forum/competitions-events/1057582-md-ca-ina-jk-america-get-trip.html
Email: kevin@methodmotorsports.net
WWW.METHODMOTORSPORTS.NET
UGET IT is offline   Reply With Quote
Old 05-02-2006, 12:15 PM   #7 (permalink)
Member # 39371
Send a message via AIM to currupt4130
I'm beating on my 44 with 38's, and its held up fine so far (3 good hard runs over the past two or three months). I have a 4 banger, but to my defense I've also got about 95:1 on the crawl ratio. My 44 is also built to the hilt, but I do run drive slugs.
The mountains are calling and I must go.
-John Muir
currupt4130 is offline   Reply With Quote
Old 05-02-2006, 12:20 PM   #8 (permalink)
GiS
GiS's Avatar
Member # 31285
Uget, you locked front and rear?
Rock Posse Racing #686
Driver: Joey Weber
GiS is offline   Reply With Quote
Old 05-02-2006, 07:01 PM   #9 (permalink)
00pumpkin's Avatar
Member # 38716
It all depends on how hard you wheel, I would try and fine some spare shafts in the meantime until you get the alloys, and im hoping that when you get the alloys that you also get CTM's or atleast a superjoint......
America is all about Speed. Hot, Nasty, Badass Speed......
00pumpkin is offline   Reply With Quote
Old 05-03-2006, 09:02 AM   #10 (permalink)
Member # 49539
Send a message via MSN to BCYJ
I think we have the same mentality, with a 4banger we don't need to build it as big as the others seeing as our 130'ish weak ponies can't turn hard enough to break weaker equiptment!!
4cyl YJ 33/12.5 BGF AT K/O's, RE4.5ED, AR 767's, Boomerangs, DT Shocks, What Swaybar? AA HD SYE,8.8/LS and 4.88's, HPD30 4.88's, 1750 KG's with all my junk.
BCYJ is offline   Reply With Quote
Old 05-03-2006, 09:11 AM   #11 (permalink)
Member # 5546
Send a message via ICQ to dennisuello Send a message via AIM to dennisuello Send a message via MSN to dennisuello Send a message via Yahoo to dennisuello
Just don't hop it with the steering turned to lock.
Denis Volkov #76 - Team Rushn' Racing - CalRocs Unlimited class
dennisuello is offline   Reply With Quote
Old 05-03-2006, 10:38 AM   #12 (permalink)
4x4 Consultant
UGET IT's Avatar
Member # 227
OX Lockers F&R
Method Motorsports
Follow Me Here: http://www.pirate4x4.com/forum/showthread.php?t=1057582
Old 05-04-2006, 07:55 AM   #13 (permalink)
GiS
GiS's Avatar
Member # 31285
Thank you.
-Joe
Driver: Joey Weber
