Backspacing - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-09-2006, 04:19 PM   #1 (permalink)
Member # 29517
Backspacing
Can you buy 16" wheels with close to hummer backspacing?
lockedandlowded is offline   Reply With Quote
Old 05-09-2006, 05:35 PM   #2 (permalink)
Philly2Crazy's Avatar
Member # 46231
Send a message via AIM to Philly2Crazy
You know hummer wheels have like 9" of backspacing right?? Why would you want that, you will rub nearly everything... I had my hummer wheels recentered to 4" of backspacing
"THE EAST STRIKES BACK" DVD - BUY IT NOW
Flex Marketing - Marketing and Web Design
RIDE Motorsports
PPR Racing
RIDE's sponsors:
TOYO Tires
Treks Mfg
Superior Axle & Gear
Pikes Peak Rovers
Oakley
Rock & Roll Offroad
Alpinestars
K&N
OGIO
KMC Wheels
Howe
Twisted DV
Philly2Crazy is offline   Reply With Quote
Old 05-10-2006, 06:18 AM   #3 (permalink)
Member # 72492
Send a message via AIM to GroundClearance Send a message via Yahoo to GroundClearance
I'm sure you can, but like was said above why would you want to? Maybe you have some super long axles....ummm......yeah
'02 TJ - '04 Rubi - '88 Wrangler YJ - '94 Grand Cherokee ZJ (RIP FEB 25 2006) -'47 CJ2A
GroundClearance is offline   Reply With Quote
Old 05-10-2006, 03:10 PM   #4 (permalink)
Member # 14004
You don't mention what bolt pattern you need, but American Racing makes the 767-6882, 5.15" bore, 12mm offset, 5" BS, 16x8, 8x6.5
I used to own a 1995 Tahoe, and recall the stock steel wheels were 6.5" wide with a 4 3/4" backspacing? I think the aluminum ones are 7" wide with the same BS...
BTW, I think H1 wheels are 9.5" wide with a 7" backspace.
82 CJ7 - TBI 304/T18a/D300/44/70/4.88/40's
87 Samurai - GSX carbs/16V 1.6/GRS-II/linked rear/31's
Kreep is offline   Reply With Quote
Old 05-10-2006, 05:46 PM   #5 (permalink)
Schmozilla's Avatar
Member # 38562
Send a message via AIM to Schmozilla
www.high-impact.net
They build some high quality customs wheels...well...deal then anyway.
Schmozilla is offline   Reply With Quote
Old 05-12-2006, 07:13 AM   #6 (permalink)
Member # 29517
I am using full width axles (chevy 14 bolt) on a buggy that will be narrower than say a stock Jeep, so width isn't and issue as far as rubbing. I was hoping that the axles wouldn't be too wide, so I was thinking of using wheels that are more centered.
Does a higer backspacing number = less off centered?
Old 05-12-2006, 08:50 AM   #7 (permalink)
Member # 14004
You might still have an issue with rubbing on leaf springs and steering arms.
An 8" rim is going to measure 9" wide. If the backspacing is 4.5" then it will be centered. If the backspacing is 7", then it will be moved inboard 2.5" and your rig will be narrower. At this point you have to worry about front hubs being exposed to rock damage.
So say you get a 10" rim which measures 11" wide. Its center is at 5.5" so that same 4.5" backspace will put the tire 1" outboard making it wider.
Old 05-12-2006, 09:35 AM   #8 (permalink)
Member # 29517
Makes sense and thanks
Old 05-12-2006, 10:31 AM   #9 (permalink)
jesster's Avatar
Member # 49468
Pretty sure my 8 bolts are 8.25" wide with a little over 7" b/s... But I would have to check to make sure...
jesster is offline   Reply With Quote
Old 05-12-2006, 10:33 AM   #10 (permalink)
jesster's Avatar
Member # 49468
Why not 17's?
Have you looked into H2's?
Old 05-12-2006, 05:36 PM   #11 (permalink)
Member # 29517
Originally Posted by jesster
Why not 17's?
No I havn't, whats the scoop on them.
Old 05-15-2006, 07:30 AM   #12 (permalink)
Member # 14004
You are correct. They are 8.25" wheels, which is how much space is available for the tire (inside measurement). But if you check the outside measurement, you will find its about 9.25" wide.
Now, if you talk about offset, which is measured from the wheel centerline it doesn't matter. But if you talk backspace, it seems to be measured from the outside of the wheel.
Please correct me if I'm wrong, this backspace/offset stuff makes my head hurt. I'm just telling you what I've figured out after spending too much time with a tape measure...
