Chevy 4.3L and Ford 8.8 Swap - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-12-2006, 11:56 AM   #1 (permalink)
Member # 68835
The stock offset for the jeep 2.5L engine is .5" off-Center Right. the D35 Diff housing is offset I think 3/4" or something to that effect.
Question:
When I swap the Chevy 4.3L & 8.8 rear-end, should I offset the engine the same?
In Other words. The ford 8.8 is around 2.75" off-Center Right almost 2" more than the D35 I have now. Should I match that with the engine? What should I do? Any suggestions?
frank0 is offline   Reply With Quote
Old 05-12-2006, 12:25 PM   #2 (permalink)
sik4wheeler's Avatar
Member # 24612
I would leave it as is, But if you want to move it don't forget about the front end. Maybe make the differnece up by moving it 1".
sik4wheeler is offline   Reply With Quote
Old 05-12-2006, 12:47 PM   #3 (permalink)
Member # 68835
I was thinking that I should just keep it at .5" offcenter. I'm putting in a CV driveshaft so the angle should be ok correct?
Old 05-12-2006, 12:59 PM   #4 (permalink)
FNG
Member # 100
Send a message via ICQ to FNG Send a message via AIM to FNG Send a message via Yahoo to FNG
you'll be fine. when I did the same engine swap I offset it 1" to the pass side and my rear is centered. The CV doesn't care as long as the total angle (side to side and up and down) doesn't exceed it's operating range.
John
FNG is offline   Reply With Quote
Old 05-12-2006, 01:57 PM   #5 (permalink)
SlowMo's Avatar
Member # 26623
With a CV shaft you won't even notice the offset. I have a 4.3l, AL460E, Atlas II, abt 7" lift, CV shaft, and a Ford 8.8. I didn't do anything to compensate for the offset and it works just fine.
This Jeep sponsered by the IRS and my tax refund.
SlowMo is offline   Reply With Quote
