Homemade Control Arms?? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-17-2006, 07:04 PM   #1 (permalink)
Member # 70279
Send a message via AIM to 97TjZack
Whats the easiest way to do this for a TJ. I need to make some adjustable rear upper control arms. I was thinking about buying some ends from a company and then making them, or maybe make the ends too. Just curious what everyone else thinks?
97TjZack is offline   Reply With Quote
Old 05-18-2006, 01:14 AM   #2 (permalink)
rckjeep's Avatar
Member # 9246
Send a message via Yahoo to rckjeep
just buy them. You'll spend more time & money making a set. Unless you just want to build them, then by all means go for it. I'd personally make them out of at the very least 1.5" x .250" wall DOM or Cromoly, but 1.75" x .375" would be better. Then I'd use a johnny joint or "flex joint" at the ends. You could could save a few bucks by going bushing on one end too. Or Heims but they need to be pretty beefy which is $$$$.
_____________________________
Contact me for info about Low Rangers 4WDC
rckjeep is offline   Reply With Quote
Old 05-18-2006, 08:40 AM   #3 (permalink)
Member # 70279
Well I was at tractor supply today looking for some parts and stuff and found a control arm for tractor with heims at both ends. Really beefy, and adjustable. 20 bucks each....Should I go this route?? With the heims on both ends, not sure how those mount up and everything?
Old 05-18-2006, 08:51 AM   #4 (permalink)
ZEUS of the JUICE!
Benzz0's Avatar
Member # 22923
those are tractor 3 point hitch links...I highly doubt they would work for you and as for the hiems they are a bigass 1" bore you can TRY and use those but report back what you find out
oh and for the 1" bolt on the hiems - press a rubber bushing inside it to reduce the bolts size
I think Billavista here made a traction bar with those like 3 years ago
The reason I swear so much is because...FUCK YOU
Benzz0 is offline   Reply With Quote
Old 05-18-2006, 09:00 AM   #5 (permalink)
Member # 50997
Those are junk, unless you have a JD!
You don't need adjustable control arms unless you plan on changing your rigs suspension often. Adjustable control arms exist only because each rig is different, and because if they use a rod end (heim) they need to be replaced due to wear about every 15K miles. Calculate the length you need and make them solid. Use a johnny joint or bushing at each end. You can build a full set of long arms using stock bushings for around $150, add the extra $$ for johnny joints if you want to use those.
MigMiester is offline   Reply With Quote
Old 05-18-2006, 09:01 AM   #6 (permalink)
Member # 70279
Whats the problem with the big bolt? Always thought bigger was better....haha.
Old 05-18-2006, 09:03 AM   #7 (permalink)
Member # 70279
Yea I guess making solid ones to the right length would be the easiest. To be honest I didnt even think of that because everyone talks about adjustables.
Old 05-18-2006, 09:07 AM   #8 (permalink)
Addicted to Gear Oil
guidolyons's Avatar
Member # 56050
Dude...Don't use tractor 3 links as suspension links. Yes, some,guys have used them as traction/antiwrap bars, but they are not up to the CRITICAL and POTENTIALLY FATAL task of supporting and locating the axles under your rig. The manufacturing tolerances/hardness/durability of tractor links are not even close to what you need for suspension links. With the amount of slop in a tractor link, your junk will be scary!
David H. Petraeus for President 2016
guidolyons is offline   Reply With Quote
Old 05-18-2006, 09:19 AM   #9 (permalink)
Member # 70279
see this is why I ask questions, I thought it was a great idea. So if I make my own, is it better to go with a bushing set up??
Old 05-18-2006, 09:32 AM   #10 (permalink)
ZEUS of the JUICE!
Benzz0's Avatar
Member # 22923
I would go bushings on the frame end and hiems on the axle end...but that's just me
1.75" - 2" OD 1/4" wall DOM would suffice...you can your rod ends from just about any suspension vendor here in the vendors section...or http://www.qa-1.com
don't forget to get the rod end inserts
you're looking at about $150+ PER ARM if you make them yourself...
