TJ rocker switches - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-01-2006, 03:47 PM   #1 (permalink)
Banned
Member # 47849
TJ rocker switches
Anyone have any links with some rocker switches that will fit perfectly in the stock locations for a TJ?
SuckyJeep is offline   Reply With Quote
Old 07-01-2006, 06:04 PM   #2 (permalink)
Member # 13889
Ask this guy: http://www.12voltguy.com/index.html
CJ7, 1 tons, 5.7l, hummers, IROK's etc., etc.
scope is offline   Reply With Quote
Old 07-01-2006, 06:57 PM   #3 (permalink)
jfab6969's Avatar
Member # 35528
The only ones that fit perfectly are the factory one, the switches from the XJ & Wj are the same also. Try www.jeepsareus.com if your local dealer isn't any help.
jfab6969 is offline   Reply With Quote
Old 07-01-2006, 08:01 PM   #4 (permalink)
Addicted to Gear Oil
guidolyons's Avatar
Member # 56050
Look here too:
http://www.4x4mods.com/
David H. Petraeus for President 2016
guidolyons is offline   Reply With Quote
Old 07-03-2006, 09:19 AM   #5 (permalink)
Member # 22489
check out a marine supply store. They often carry switches that will fit perfectly.
raskal is offline   Reply With Quote
Old 07-03-2006, 09:38 AM   #6 (permalink)
Member # 1370
Ditto that. I got mine at West Marine.
Paul
www.jeepshots.com
nasvik is offline   Reply With Quote
Old 07-03-2006, 08:48 PM   #7 (permalink)
Member # 16217
Send a message via ICQ to JeremyH Send a message via AIM to JeremyH
Carling's Contura switch fits perfectly in the stock location.
JeremyH is offline   Reply With Quote
Old 07-04-2006, 06:29 PM   #8 (permalink)
Member # 65809
i worked at napa for awhile and did spend alil time finding High quality rocker switches to run my night lights for the trail . they have picture books that show all the switches .. the one i found is White with an Amber light panel offset in the middle of switch that lights up to let you know you have power going to what ever your running its the Eclin brand of switch.. it fits perfect once you trim the hole out for it ... they cost bout 15 bucks but it was quality i was going for when i found them they are a high amp rating also ... if i still worked there i would get you the part # but that was last year
07 Harley Davidson FLHTC 131 inch 7 speed
06 F150 King Ranch super crew cab 4x4 77 Sanger v-drive
CreepyCrawler is offline   Reply With Quote
Old 07-05-2006, 07:10 PM   #9 (permalink)
Member # 73681
I got mine from www.migoffroad.com
Pretty cheap and fit right in.
solar1 is offline   Reply With Quote
