Member # 46937
No keys and column is locked
79 CJ. Bought it as a project and don't have the keys.
Anybody know how to get the lock out of the column? ________ Colorado marijuana dispensaries Last edited by atblis; 08-11-2011 at 11:52 PM. |
Member # 66647
You could pull the wheel and cut the pin but it wouldn't ever work again, but then again its not going to work.
79 CJ-7 95 ZJ Last edited by KiGrind; 09-10-2006 at 10:40 AM. |
#3 (permalink) | |
Addicted to Gear Oil
Member # 56050
It's been a few years since I did one... IIRC Remove steering wheel, Push down and remove the snap ring remove lockplate (it's spring loaded be careful) and turn signal assembly. Then you can remove the retainer clip that holds the lock cylinder. Replace with new lock cylinder. Reassemble.
Get a Haynes Manual ($15) it should have directions and pictures, etc. Lock cyinder with keys will be approx $15. You may need a steering wheel puller and a lock plate remover, you can usually rent, buy for cheap, all at your favorite local autoparts store.
1965 Scout 80 7.3PSD/ZF/203/205 D60F/14BFF Member: 4 Jackstand Wheeler's Association Quote:
David H. Petraeus for President 2016 |
Member # 46937
Didn't think of looking in the Haynes manual. Doesn't sound too bad.
Thanks, Andrew ________ Iolite Vaporizer Last edited by atblis; 08-11-2011 at 11:53 PM. |
Member # 71834
Just did mine when my keys went scuba diving to the bottom of the lake. The manul will say that the cylinder must be in the on position. It doesn't just make sure that the new cylinder is in the same position as the old one when installing it. You should be able to pick up a new cylinder at any parts depot ( autozone) for $11- 13. Not to bad.
Get the Haynes/Chilton manual. I just did this in my 85 CJ, it has the same basic column as my 73 javelin. I didn't have a manual when I did the Javelin and broke a few smaller pieces. The manual shows you a couple little tips that make it a lot easier. pictures help to.
Oh you sir. You are definitely fired. |
