Front dana 60; Ford or Chevy? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-10-2006, 10:57 AM   #1 (permalink)
webdr's Avatar
Member # 70984
Seems like the Chevy dana 60 is more desirable but why? They often go for twice as much as a Ford dana 60 front. Im going 1 ton on my cj5. I have a sterling 10.25 and now im looking for a front. At this point, it can be passenger or drivers side drop. I have no preference. Anybody know the difference in the two?
webdr is offline   Reply With Quote
Old 09-10-2006, 04:28 PM   #2 (permalink)
Member # 78957
i would say that you dont have a choice
seeing how the ford front pumpkin is driver side and i believe your cj requires an axle with the pumpkin on the passenger side. thats if you plan on using the same t case.
gonnamakea1tonxj is offline   Reply With Quote
Old 09-10-2006, 04:30 PM   #3 (permalink)
Member # 78957
the chevy steering hubs are stronger than the ford
Old 09-10-2006, 07:41 PM   #4 (permalink)
Phantom1016's Avatar
Member # 67642
dodge Passenger drop if you plan on using stock TCase, chevys shouldnt be that much more expensive, probably looking at flat top knucles or kingpins, but both are driver side drops
"I can do all things with a sawzall who strengthens me" - Philippians 4:13, or something like that
Phantom1016 is offline   Reply With Quote
Old 09-10-2006, 08:06 PM   #5 (permalink)
webdr's Avatar
Member # 70984
Im not using the dana 20.
The game plan is auto trans, 1 tons, rear link. Do others agree the chevy knuckles are stronger?
Old 09-10-2006, 08:14 PM   #6 (permalink)
Simply awesome!
Member # 5679
High Pinion is sexay though.......
1bgdog is offline   Reply With Quote
Old 09-10-2006, 08:17 PM   #7 (permalink)
Newbie
DreamsOfMoab's Avatar
Member # 74072
Chevy, those 60's come with kingpins rather than the balljoints that Ford 60's come with (which makes them both stronger, and more desirable)
DreamsOfMoab is offline   Reply With Quote
Old 09-10-2006, 08:43 PM   #8 (permalink)
Member # 77602
The 78-79 Ford 60s have high pinion, they are also kingpins. U can find them on ebay they sell for around $1000. I was lucky to get one completed in good shape for $580
Blue1TonYJ is offline   Reply With Quote
Old 09-11-2006, 06:54 AM   #9 (permalink)
webdr's Avatar
Member # 70984
good info, thanks
Old 09-11-2006, 11:15 AM   #10 (permalink)
LCAC_Man's Avatar
Member # 35307
Chevy knuckles do have a bit more material on them and use a six bolt pattern for the spindle vice the 5 bolt that the Ford uses, I don't know that the difference in strength stock to stock is much though. You can weld in some gussets and plating to beef either of them up considerably. You can also use chevy/dodge outter knuckles on a ford housing, this will allow you to use the Dana 70 outter 35 spline shaft which is about the cheapest 35 spline outter setup. The ford housing is high pinion which offers some additional clearance and the gears are reverse cut so they are a bit stronger than the chevy/dodge counterparts.
Len Barron
72 Commando/LS2/4L65e/NP241
DRWHP60-ARB/14B-Detroit/4.56/H1's/37's
Bullnose Build in Progress
Stretched Bullnose
LCAC_Man is offline   Reply With Quote
Old 09-12-2006, 08:58 PM   #11 (permalink)
bjb
Member # 56602
best way in front is high pinion ford center with chev/dodge knuckles and 35 spline outers. Read the bible.
bjb is offline   Reply With Quote
Old 09-16-2006, 07:53 AM   #12 (permalink)
webdr's Avatar
Member # 70984
Originally Posted by bjb
Read the bible.
Would that be the dana 60 bible? where is that located?
Old 09-16-2006, 01:46 PM   #13 (permalink)
Kevie Ray's Avatar
Member # 49165
http://www.pirate4x4.com/tech/billav...ont/index.html
"Stepping into the sound waves of Stevie Ray Vaughan's blues was like walking into the wash of a jet engine naked"
BRC MEMBER
CA4WDC MEMBER
FOTR MEMBER
Kevie Ray is offline   Reply With Quote
Old 09-16-2006, 04:34 PM   #14 (permalink)
bulfrog3's Avatar
Member # 11890
They had king pins all the way to 91, 92 they went to ball joints.
bulfrog3 is offline   Reply With Quote
Old 09-19-2006, 03:51 PM   #15 (permalink)
Member # 49539
Send a message via MSN to BCYJ
My first statement would have been read the bible.
My second statement would be ditch the boat anchor 10.25. Its Fugly, go 14 bolt or D60 rear.
4cyl YJ 33/12.5 BGF AT K/O's, RE4.5ED, AR 767's, Boomerangs, DT Shocks, What Swaybar? AA HD SYE,8.8/LS and 4.88's, HPD30 4.88's, 1750 KG's with all my junk.
BCYJ is offline   Reply With Quote
Old 09-20-2006, 07:04 AM   #16 (permalink)
webdr's Avatar
Member # 70984
who cares???
I already have the axle, its not that ugly IMO and has better ground clearance than a 14 bolt. Its stronger than a 60 so why would I ditch it?
Old 09-20-2006, 08:22 AM   #17 (permalink)
tmf
Member # 52485
I have a 10.25 in my yj. weld it and get a diff. cover for it, they are paper thin. can't beat factory 35 spline. you will be happy with it.
[B]RIP [/B]92 YJ, 2.5L, 60F, 10.25R, Toy Trans & 4.7 Box, 42's
WB-104"
New Rig - 93 FJ80, OME, Locked, 295/75/16, It's a PIG
[B]KGB 4WHEELERS[/B]
tmf is offline   Reply With Quote
Old 09-20-2006, 04:50 PM   #18 (permalink)
webdr's Avatar
Member # 70984
nice... Do you have any pics of your 10.25?
