For those have done the 8.8 conversion. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-15-2006, 06:19 AM   #1 (permalink)
jsawduste's Avatar
Member # 77571
I am upgrading the 4 cylinder manual trans. YJ as funds (and parts) become avaliable.
Question;
I have a 8.8 ready to install. Can I use the stock driveshaft without the SYE ?
The transfer case is going to be a JB 231HD with the SYE but it will not be ready for a few weeks. I`d like to get the 8.8 installed in the mean time. But need to know if I can get away with using the stock 4 cylinder/5 speed drive shaft till the JB 231 comes in.
Course I will not be using the 4WD with the front 4.10`s.
The front HP44 will not be done for a few weeks also. At that point I will do the driveshaft dance on both ends.
Thanks
jsawduste is offline   Reply With Quote
Old 09-15-2006, 08:31 AM   #2 (permalink)
Member # 29571
It'll work.
rbaer is offline   Reply With Quote
Old 09-15-2006, 08:59 AM   #3 (permalink)
Member # 42789
Been there done that. No problems at all
'95 YJ w/OME lift, 33" SSRs, front & rear ARB, and a Warn 8274, NOW WITH FORD 8.8 & 4.0L
Chinook Country Jeep Club
ECO Four Wheeling Society
Calgary Jeep Association
CCJC is offline   Reply With Quote
Old 09-17-2006, 09:23 PM   #4 (permalink)
kris1351's Avatar
Member # 40704
Yes, no problem. Ran mine for 8 months without an SYE on it.
Kris
Buy it, use it, break it, fix it, trash it, change it, melt - upgrade it
http://www.myjeepsite.com - Free Pic Hosting & Blogs
http://www.ncserv.com - Premier Web Hosting Solutions
kris1351 is offline   Reply With Quote
Old 09-19-2006, 07:02 AM   #5 (permalink)
Member # 16901
Send a message via AIM to jeepfreak81 Send a message via Yahoo to jeepfreak81
No problems with it stock, I also run the same shaft with my 355 and 33's, I do carry a spare shaft now just in case I blow it though.
1994 Wrangler -- 355 Chevy, 700R4, D44, D60, 37's
1946 CJ2A -- 225 V6, and 34's towing a 1966 M416
jeepfreak81 is offline   Reply With Quote
Old 09-19-2006, 07:07 AM   #6 (permalink)
Member # 27390
the 8.8 pinion is actually longer, so the SYE is in a way needed less cause the longer pinion gives you a little length back to the set up
[COLOR="Red"]"In vino, veritas"[/COLOR]
supernatural is offline   Reply With Quote
Old 09-22-2006, 08:59 AM   #7 (permalink)
Member # 68697
However the offset pinion adds a new degree (no pun intended) of fun when trying to fight vibration without a SYE. When I did my 8.8 I just saved the pennies for the SYE right away for this reason.
Mike
mingoglia is offline   Reply With Quote
Old 09-22-2006, 03:27 PM   #8 (permalink)
Member # 78408
How is the 8.8 setup?? The spring perches need to be in different places to get the correct pinion angle for a stock driveshaft versus a CV driveshaft. If you don't need to drive it before the t-case comes in, you will save yourself lots of duplicate work by waiting.
I've welded my spring perches 3 times so I know what a pain in the butt it can be.
The offset pinion shouldn't cause any vibrations because the pinion will still be parallel with the centerline of the vehicle and the t-case output will also be parallel with the centerline of the vehicle so the u-joint angles (when viewed from above) at both ends will be the same.
KC2OTE is offline   Reply With Quote
