Member # 77979
Hace a 80 cj-7 with 33 MTR's looking for anyone running the dana 30 and amc 20 with 4.10's and 33 or 35's or any tire for that matter with a four speed. I need to know if hightway use is still an option I have checked with the gear to tire calculator that tells what rpm at 60mph. I have got numbers from 2700 to 3200. Is this two much for the 258. This jeep is not a daily driver but does see the higheay to travel to trails. I am considering 35 MTR at a latter time but the 33 are brad new. I would like some feed back from anyone running this set up even if it is in a 5speed. thanks ep
80 CJ-7 another work in progress |
Member # 31529
speed
no problem for years, just do not plan on going 70mph
258,T18, klun,d300, d30/arb,amc20/with fullfloat detroit. 33in for years now 35 need lower gears. want to buy two well set up axles? |
Member # 77979
Thanks guys, I have not yet bought the parts and I guss you can't have the best of both worlds. what rpm does your 258 run at 65 and I wonder how 373 would do with 33's, ep
Member # 40690
In my opinion (whatever that's worth) 4.10s/33s/5spd is a great setup for a rig that is driven to the trail. Driveability is very close to stock.
I ran this setup for a couple of years before going V8/auto- now I kinda wished I had kept the 5spd for the OD.
1990 4Runner, 4" procrap lift, 4.88 gears, Arb locker rear, Detroit Trutrac front, 33" MTs |
I ran 4.56 T-18 32's for years and hated the 4-5hour drive to the trail head. In fact I hated being on Callifornia Freeways period.
I went to 35's and it was ok. I'm now going to 4.10's and later I'll install a 4:1 in the D300. Like I said my 4 speed is a T-18, so the granny is not used at all w/4.56 on the street. And the 2nd is barely needed with 4.56 on 32's. In other words I basically had a 2 speed on the street.
I've been gone a while, but I'm still hang'n in there! |
Member # 56602
A buddy had a '80 cj7 with 4.10s and 33s. Drove it all over (many trips across nevada at 70-80mph) but had a header, 4 barrel, and cam in the six. The stock motor doesn't like turning 3 grand too much. I had a cj7 with 4.10s and five speed on 33s and stock 6cyl and that was nice on the road but pretty gutless. I think 35s with the 4.10s is a better combo than 33s but I'd rather have 4.10s planning to go to 35s than need to change gears again when I went to 35s.
Member # 77979
4.10's and 4 speed
Thanks to all who replied, I have decided to go with the yukon 4.10 gears and one piece axles I think this will still give me some streetabilty, This jeep is not a daily driver so I can stand alittle hit at the pump. I'm also insalling an Aussie locker in the rear. I have already installed a hedmen header, 36dg Weber carb, and comp cam. I am going through the complete jeep this winter. This is a great site for info. ep
