Which rear axle do you think is best and why? - Pirate4x4.Com : 4x4 and Off-Road Forum
View Poll Results: What rear axle do you recommend?
HP60 16 22.54%
14b 33 46.48%
9" 13 18.31%
Other, explain. 9 12.68%
Voters: 71. You may not vote on this poll
Old 09-24-2006, 01:47 AM   #1 (permalink)
Cue
Cue's Avatar
Member # 28682
Okay I have a 96 ZJ, 4.6 stroker and a custom 42/46RE trans.
I am in the process of planning out my full width axles. I will be doing a HP60 in the front and need some opinions on what to put out back.
I want to still be able to drive it on the street (not as a DD) but to and from the trails. I will be running 38-42" tires, full spool out back, I don't just rock crawl, I pretty much like all types of wheeling so I want a good all around axle.
If I go 14b it will get shaved so ground clearence is not a huge issue. I am concerned that the 5.38 gears may not be low enough with the big meats and my 6cyl.
I def. want a FF'er, 8 lug. I will be running Clayton's long arms, Clayton's high clearence brakets on what ever axle I end up with.
Well I think that pretty much explains what I am looking for and some info on the Jeep and my driving, so what do you recommend?
Your #1 Source for Amsoil Lubricants
Lube it or Loose it!
Cue is offline   Reply With Quote Quick reply to this message
Old 09-24-2006, 01:05 PM   #2 (permalink)
bigblackblur's Avatar
Member # 44321
Send a message via AIM to bigblackblur
I voted 14 bolt. They are cheap as hell. They can be shaved to save a TON of ground clearance, and there is alot of developed and developing aftermarket support for them, and in stock form they are stronger than any of the other axles on the list.
bigblackblur is offline   Reply With Quote Quick reply to this message
Old 09-24-2006, 01:11 PM   #3 (permalink)
sand dune coon's Avatar
Member # 57123
i would run a 60 , you got the hard part done already up front and with a 60 u wont have to shave it and u can run any gears you want.. but hell the 14 bolt will be fine to,, either way,,, but i wouldnt run a 9" but thats just me..
sand dune coon is offline   Reply With Quote Quick reply to this message
Old 09-24-2006, 01:52 PM   #4 (permalink)
Member # 784
Your three poll options are very different.
The 9" is a SF half ton axle, with five lug bolt pattern. Can be cheap, or blingy expensive.
The 14B is big, FF, with eight lug pattern. Fairly cheap.
HP60 would be a custom only option, $$$.
5.38 is as low as you can go in a HP 60, so lower gearing options is a non-issue.
Think for yourself
JEEPRZ is offline   Reply With Quote Quick reply to this message
Old 09-24-2006, 02:52 PM   #5 (permalink)
Cue
Cue's Avatar
Member # 28682
Yes if I went with a 60 it will be a RockCrusher center and then the rest custom made. That is what I am planning with my front HP60 already.
I thought you could go up to 7.x:1 gears in the 60's?
I am planning on either a Stak TC or a flipped D300, I will have 4:1 gears in the TC so if getting lower than 5.38's at the axles really worth it?
I am leaning towards the 14b due to the cost and with the money I will spend on the front I really don't want to break the bank out rear also.
Any other opinions??
Old 09-24-2006, 03:04 PM   #6 (permalink)
Member # 69441
You can go all the way up to 7:17 with a LP 60 but 5:38 is the highest for a HP 60. How about a LP 60 in the rear?
Lj stretched Dana 80s 47s coilovers 5.8 aodw 203 205
99grandtj is offline   Reply With Quote Quick reply to this message
Old 09-24-2006, 03:06 PM   #7 (permalink)
Member # 44321
The gear ratio topic is pretty much killed because he is running an HP 60 in the front.
If you were looking for gearing options the 9" is the king, that thing goes all the way from either 3.10 or 3.55 all the into the 7s or so.
Old 09-24-2006, 03:07 PM   #8 (permalink)
Cue
Cue's Avatar
Member # 28682
Thanks for the clarification.
I think if I am going to go to the exspense of building a rear 60 I might as well go HP.
Old 09-24-2006, 03:15 PM   #9 (permalink)
Member # 69441
Yes the HP is nice and I agree. But is still will be cheaper to build a LP. Plus when your at the 5:38 gear level and running a HP in the rear it starts breaking ring and pinions, although the LP is not much stronger in the gear department it is alittle. My .02
Old 09-24-2006, 11:37 PM   #10 (permalink)
Member # 18601
"I will be running Clayton's long arms, Clayton's high clearence brakets on what ever axle I end up with." GREAT IDEA ON THE CLAYTON STUFF I KNOW HIM PERSONALLY AND HIS STUFF IS SECOND TO NONE. I VOTED 14B BECAUSE I MADE THE MISTAKE OF BUILDING THE 60 AND COULD HAVE SAVED SOME CASH AND STILL BEEN STRONGER WITH THE 14B.
88YJ
67M715
00Excursion 7.3
SVENG52 is offline   Reply With Quote Quick reply to this message
Old 09-25-2006, 12:02 AM   #11 (permalink)
Member # 44321
OUCH CAPS LOCK! Ahh thats better.
Old 09-25-2006, 06:08 AM   #12 (permalink)
Cue
Cue's Avatar
Member # 28682
I do not want to get off track by comparing long arms. I will be running Clayton's also and honestly that is the first time I have ever heard anything negative like that about Clayton's.
I think I am still leaning towards the 14b just from a cost stand point.
Old 09-25-2006, 07:13 AM   #13 (permalink)
Member # 69049
Send a message via Yahoo to jeeperak
14b sounds like your best bet for your build.
i thought(now im too damn lazy to look for the thread) he destroyed a rock krawler set up.
STFU bitches, it's Santa". whoops.
jeeperak is offline   Reply With Quote Quick reply to this message
Old 09-25-2006, 07:29 AM   #14 (permalink)
KaiserJeepMan's Avatar
Member # 72070
I voted other, cause I would pick a Dana 70. You can get them in way more forms then a 14b (D70, D70U D70HD etc.) some of which are noticibly stronger then a 14b. The basic D70 is often said to be a smidge stronger then the 14b actually. I'm a Dana/Spicer man myself.
1971 Jeep J2000, 1969 Jeep J3000, 1963 Jeep J300
KaiserJeepMan is offline   Reply With Quote Quick reply to this message
Old 09-25-2006, 07:37 AM   #15 (permalink)
Cue
Cue's Avatar
Member # 28682
A buddy of mine actually has a D70 housing from a DRW vehicle he said I could have for free if I wanted it, it is just the housing.
I am not really familiar with the D70's though. The pumpkin is the same at the D60, but has a bigger Ring gear correct??
Old 09-25-2006, 09:42 AM   #16 (permalink)
Jeepman14wheel's Avatar
Member # 46071
14 Bolt, cannot beat the price and strength!
Jeepman14wheel is offline   Reply With Quote Quick reply to this message
Old 09-25-2006, 10:49 AM   #17 (permalink)
JDunn's Avatar
Member # 33065
I would go to the junk yard and spend about $100 on a 30 spline LP 60. Put new perches on it new R&P and a locker and call it good.
79' CJ7 Buggy
KI6TLZ
WeBilt 4WD Club
JDunn is offline   Reply With Quote Quick reply to this message
Old 09-25-2006, 09:38 PM   #18 (permalink)
Member # 79320
Send a message via AIM to 80cj-5
Now ya see it all matters on what you are going to do with your vehicle and how big it is. If its a Samurai I think a 60 or a 14 bolt is a tid bit over kill and a 9in. or a 44 would be perfect. Now a fullsize would require a 60 or 14 bolt without second guess. But for your ZJ build up I would deff go HP 60 up front with a 70 or a 14bolt out back.
80cj-5 is offline   Reply With Quote Quick reply to this message
Old 09-26-2006, 12:30 AM   #19 (permalink)
Member # 18601
X2 CLAYTON STUFF DOES NOT GRENADE ON ITS FIRST TRIP ATLEAST NOT IN MY EXPERIENCE. FURTHER ON THE REAR END I HAVE BROKEN SEVERAL 30 SPLINE REAR 60 SHAFTS SINCE I GOT MY NEW ENGINE BUILT.
88YJ
67M715
00Excursion 7.3
Old 09-26-2006, 01:06 AM   #20 (permalink)
Member # 43871
I voted 9" just from info given. I've seen custom modded 9" centers that held 10" ring gears and had 40+ spline ff axles that were like 2-1/2 to 3" thick on prerunner rigs built for baja, in Tucson that run around $8grand. I didn't know there was a $$$ prerequisite. My bad. Hopefully, I'm going to build one of these soon as cheap as possible...
Part Dodge
Part Chevy
Part Humvee
Mostly Jeep...
All American.
Good is offline   Reply With Quote Quick reply to this message
Old 09-26-2006, 06:44 AM   #21 (permalink)
Cue
Cue's Avatar
Member # 28682
Well I know if I even mentioned I was going to spend $8k on an axle my wife would kick my ASS!!!!!!!!!
Old 09-26-2006, 10:29 AM   #22 (permalink)
JDunn's Avatar
Member # 33065
Read my post above and go with a LP D60 it is stronger and cheeper than a HP D60 and you don't loose that much clearence. You could spend $8K on an axle or you could build a stout rig for $8K and still be good with the wife.
79' CJ7 Buggy
KI6TLZ
WeBilt 4WD Club
Old 09-26-2006, 11:03 AM   #23 (permalink)
Cue
Cue's Avatar
Member # 28682
I wish I only had $8k into the ZJ.
Old 09-26-2006, 12:30 PM   #24 (permalink)
jesster's Avatar
Member # 49468
I don't see why this would this be a better option than a shaved 14 bolt unless a R&P ratio lower than 5.38 is needed...
jesster is offline   Reply With Quote Quick reply to this message
Old 09-26-2006, 12:38 PM   #25 (permalink)
Member # 43871
I agree guys, for the money get and shave a ff14.
Part Dodge
Part Chevy
Part Humvee
Mostly Jeep...
All American.
