CJ 350 motor radiator with 258 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-25-2006, 12:26 PM   #1 (permalink)
Member # 74950
i can get a good quality cj7 radiator that is to be used with a 350 conversion, but im using it instead with the 258. will this work, are the input and output pipes on the radiator in the same place, or do i need to get special hoses
kab5437 is offline   Reply With Quote
Old 09-25-2006, 04:13 PM   #2 (permalink)
Member # 72257
I "think" the radiator ports are on different sides....not sure. If so, you can use that flex-hose and get creative with some necking material. The only problem i see is the upper hose comes out of the thermo houseing pretty dang close to the belts. you're going to want to pay special attention to that.
I drive the fastest barbecue on 4 wheels...
CJim7 is offline   Reply With Quote
Old 09-25-2006, 08:29 PM   #3 (permalink)
Member # 79320
Send a message via AIM to 80cj-5
Yepp, they are on different sides, CJim7 is right about the flex hose but make sure you attach it away from the fan and belts.
80cj-5 is offline   Reply With Quote
