Axle swap questions for my YJ - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-14-2006, 02:24 AM   #1 (permalink)
Member # 73300
I've done a lot of searching around for this info and haven't been able to find out all of what i'm looking for. I found a dana 44 front axle out of a '78 ford truck. I haven't talked much with the owner yet and all i know is that it's 8 lug and has warn hubs. is this a good axle to swap into a YJ? (i'm planning on going SOA with a dana 60 rear and run 37 inch tires)
anybody know the stock width (WMS to WMS) of the '78 dana 44?
also, what does "reverse cut" mean?
2000 F250 7.3 PSD
Stangman516 is offline   Reply With Quote Quick reply to this message
Old 10-14-2006, 04:27 AM   #2 (permalink)
Member # 13889
It's going to be around 65-67" wide.
"Reverse cut" means that, like your YJ dana 30, the ford is a high pinion axle.
CJ7, 1 tons, 5.7l, hummers, IROK's etc., etc.
scope is offline   Reply With Quote Quick reply to this message
Old 10-14-2006, 09:37 AM   #3 (permalink)
sand dune coon's Avatar
Member # 57123
no not a good axle, u want a 79 or newer those are high pinion also known as reverse cut..
sand dune coon is offline   Reply With Quote Quick reply to this message
Old 10-14-2006, 11:47 AM   #4 (permalink)
Member # 69441
It is a great axle for what you want. It is a hp 44. IIRC if it is a F-250 not a converted F-150 it bolts in soa. If it is 8 lug it will be more like 68-69" wms.
Lj stretched Dana 80s 47s coilovers 5.8 aodw 203 205
99grandtj is offline   Reply With Quote Quick reply to this message
Old 10-14-2006, 12:04 PM   #5 (permalink)
Member # 73300
Awesome. thanks!
2000 F250 7.3 PSD
Old 10-14-2006, 02:47 PM   #6 (permalink)
H Rated
jethrodeg's Avatar
Member # 36099
Hey.... I have a 1979 8 lug F250 HP44 4:10 w/lock-right for sale. And yes the y are 69" wms. Both sides have machined flat tops for high steer. I have the pads adjusted for the spring centers. Straight bolt on. It is in perfect working condition. I am close to you as well. Let me know if you are interested.
jethrodeg is offline   Reply With Quote Quick reply to this message
Old 10-14-2006, 08:04 PM   #7 (permalink)
Member # 73300
PM sent!
2000 F250 7.3 PSD
Old 11-13-2006, 05:34 AM   #8 (permalink)
Member # 16008
hp 44 front, 9" rear with arb's and 37" mtr"s under my 89 wrangler.If you plan on wheelin it hard replace the stock axle shafts with some modern metalurgy...,I would save you this trouble.
billmtnman is offline   Reply With Quote Quick reply to this message
