60 disks rear - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-18-2006, 07:09 AM   #1 (permalink)
gna
Member # 15498
60 disks rear
I just finished a 60. I put Moser 35 splines on it. I have Zuki disk and calipers on it now. I have the Firebird master in from awhile ago. Ford big bearing ends. I can't seem to find any rotors that have the right size hat to slide over the axle flange and be 5.5 pattern. Any suggestions? I guess the sammy stuff works ok,but would like some vented rotors on the rearw/gm calipers
gna is offline   Reply With Quote
Old 11-18-2006, 06:15 PM   #2 (permalink)
Member # 21815
Wilwood 4 piston...pricey , but they'll lock up 40's. This is a 60" WMS 60 with Dutchman 5x5.5 and Ford big bolt big bearing flanges...
WWDD?
N6YBH
"If you need a tool and don't buy it, you will ultimately find that you have paid for it but don't have it". -Henry Ford
Use Goodsearch and support the Rubicon Trail Foundation.
resqme is offline   Reply With Quote
Old 11-18-2006, 06:35 PM   #3 (permalink)
W_B
Member # 64758
man thats huge..
gotta get me 1
W_B is offline   Reply With Quote
Old 11-18-2006, 07:44 PM   #4 (permalink)
bjb
Member # 56602
I got exploer brakes on mine.
bjb is offline   Reply With Quote
Old 11-18-2006, 09:32 PM   #5 (permalink)
Member # 79038
Contact Rockcrusher, now Solid Axle....(330) 538-9791...I got a Ford Motorsport Disc brake kit for my 60 from them....It is excellent and should work very well for you...btw, I'm running the Moser shafts also....they might be able to hook ya up with the rotors only...I'm running the same 5-5.5 bolt pattern...
Sahara01 is offline   Reply With Quote
Old 11-20-2006, 02:47 PM   #6 (permalink)
gna
Member # 15498
What about gutting the stock porportion(sp) valve ? anyone done it?
Old 11-21-2006, 11:25 AM   #7 (permalink)
Member # 21815
I used a combination valve designed for 4 wheel disks in my application. It came from Master Power.
WWDD?
N6YBH
Old 11-25-2006, 03:01 PM   #8 (permalink)
gna
Member # 15498
Couldn't find it on the master power page.
Old 11-25-2006, 08:11 PM   #9 (permalink)
Member # 21815
http://www.mpbrakes.com/products/pro...product_id=614
WWDD?
N6YBH
