H1 Wheels on CJ5 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-26-2006, 11:20 PM   #1 (permalink)
Member # 69676
Send a message via AIM to christhesav
H1 Wheels on CJ5
I am looking to put h1 wheels on my CJ5. i am running 14 bolt and dana 60. will these wheels fit without hitting my drums in the rear? what issues will i run into if any? thanks
christhesav is offline   Reply With Quote
Old 11-27-2006, 08:24 AM   #2 (permalink)
ZEUS of the JUICE!
Benzz0's Avatar
Member # 22923
well they are the same bolt pattern and the H1's have larger brakes OEM so I don't think you will have a problem...
what brakes are you running now?
The reason I swear so much is because...FUCK YOU
Benzz0 is offline   Reply With Quote
Old 11-27-2006, 11:03 AM   #3 (permalink)
Member # 14004
The rear should be fine, I ran them on a Dana 70 rear for a while. You may hit the tie rod in front unless you run a spacer, on my Dana 44 front I needed a 1.5" spacer to clear.
82 CJ7 - TBI 304/T18a/D300/44/70/4.88/40's
87 Samurai - GSX carbs/16V 1.6/GRS-II/linked rear/31's
Kreep is offline   Reply With Quote
Old 11-27-2006, 11:24 AM   #4 (permalink)
Member # 69676
I am just running stock drum brakes in the rear right now, but i am planning on running disk brakes soon.
Old 11-27-2006, 12:41 PM   #5 (permalink)
Member # 14004
They are 16.5 inch wheels so they should clear your calipers fine. The 7 inch back spacing can be an issue on the front though.
Also, since the wheel is 8.25" wide (9.25" overall) only 2.25" of wheel covers the hubs so they are vulnerable to some serious rock hits.
Old 11-27-2006, 12:47 PM   #6 (permalink)
sodaboyYJ's Avatar
Member # 17421
Send a message via Yahoo to sodaboyYJ
You should generaly expect the front rims to hit the tie rod ends.
Hey Benzz0, H1's have inboard brakes, it's the portal box that lives in the huge backspacing.... not the brakes.
'93 YJ, 5.0/C6/Atlas 4sp/ 38.5 SX's...D60's F&R with ARB's on coils
sodaboyYJ is offline   Reply With Quote
Old 11-27-2006, 03:27 PM   #7 (permalink)
ZEUS of the JUICE!
Benzz0's Avatar
Member # 22923
Originally Posted by sodaboyYJ
hey Benzz0, H1's have inboard brakes, it's the portal box that lives in the huge backspacing.... not the brakes.
you know after I had a couple more cups of coffee that came to mind
meh....those wheels will work dude and whateveryoneelse said about the front may be an issue
Old 11-27-2006, 11:45 PM   #8 (permalink)
Member # 69676
what are people doing to keep the wheel away from tie rod ends in the front? i am planning on running hi steer arms.
Old 11-28-2006, 06:46 AM   #9 (permalink)
sodaboyYJ's Avatar
Member # 17421
Buy the proper hi steer arms! Several companys have great arms that will easily clear the rims. I chose WFO HD double ended arms, not only do they look sweet, they allow you to run the tie rod behind and above the axle.
Old 11-28-2006, 06:48 AM   #10 (permalink)
sodaboyYJ's Avatar
Member # 17421
No worries, I only metioned it as a point of clearity, wasn't trying to bust yer balls
Old 11-28-2006, 11:34 AM   #11 (permalink)
Member # 66280
The stock location of the tie rod on the dana 60 will not work with the H1 wheels. If you do have a 60 front
here is what I did on my CJ-7, cut the stock tierod locations off with a sawzall about 2" back on the knuckle, grind them down kinda rounded off
I got 2 hy-steer arms from Aaron at www.harshterrain.com
they are offset and specially made for the hummer rims, on my arms I had 2 holes drilled for the large 1 ton tre's used on the Chevy, dodge 1 ton axles
this moved my tierod up over top of the axle and Keeps it safe from rocks, or safer. If you use the stock tierod it will need to be shortened to compensate for the offset hy-steer arms
I used the big tre's for the draglink too, If you do this you will need to replace your pitman arm with a waggy pitman arm, It is beefier and can be drilled for the big tre
guffey24 is offline   Reply With Quote
Old 11-28-2006, 12:01 PM   #12 (permalink)
Phantom1016's Avatar
Member # 67642
You can use stock tierod location with DRW hubs, but that opens up a new can of worms
x2 on cutting stock steering arm and going to hi steer
"I can do all things with a sawzall who strengthens me" - Philippians 4:13, or something like that
Phantom1016 is offline   Reply With Quote
Old 11-29-2006, 12:14 AM   #13 (permalink)
Member # 69676
thanks for the info
Old 11-30-2006, 09:30 AM   #14 (permalink)
Member # 69676
does anyone have any pictures of their steering set up with their h1 wheels?
Old 12-01-2006, 05:25 AM   #15 (permalink)
Member # 66280
I will post some in the morning
Just a little buggy
Old 12-01-2006, 05:54 AM   #16 (permalink)
sodaboyYJ's Avatar
Member # 17421
Admittedly, these are pretty dark, but hopefully you'll be able to get the point
Old 12-11-2006, 03:44 AM   #17 (permalink)
Member # 21858
Buy or build the proper hi steer arms!
ive have done it
same setup ford 78 hp d60 in front
14 bolts rear first with drums now with disks
h1 8 bolts
cj5 76
SOA,OBA,OBW,LPG
14b & 60RC W/detroits
High steering and ram assisted
ford t18 and 205 , rear Fox air shocks
new toy Cj7 82 on 33's setuped to mall crawling :D
MCgiver4x4 is offline   Reply With Quote
Old 12-12-2006, 07:23 AM   #18 (permalink)
Member # 66280
wanted to add another thing on the H1's, and steering issues
I didnt want to put the tierod up and behind the axle because of oil pan issues, so I put it up and forward
my only option was to move the steering box forward 1.5 inches
Just a little buggy
Old 12-12-2006, 07:52 AM   #19 (permalink)
Member # 20839
Is that pic the location of the draglink before moving the box forward? What pitman arm are you running? 3/4 or 1 ton TRE's?
sorry for all the questions. Just reading up before i tear into mine
Brendan
46 CJ2A
mbatvburg is offline   Reply With Quote
Old 12-12-2006, 12:21 PM   #20 (permalink)
Member # 66280
that pic is before the box was moved forward
the tre's are 1 ton, If you decide to use 1 ton tre's use a waggy pitman arm, it will fit on a CJ power steering box
reason for using the waggy arm, is because it is overall bigger especially on the end where the tre hooks
using a 1 ton tre, the end of the pitman arm will have to be tapered, I didnt feel there was enough material on the end of the stock CJ arm to taper it for the 1 ton tre, it would have been a weak point
Just a little buggy
Old 12-12-2006, 08:11 PM   #21 (permalink)
Member # 83755
What about running H1 wheels on a D44?
KILLERxj16 is offline   Reply With Quote
Old 12-13-2006, 04:53 AM   #22 (permalink)
Member # 66280
the D44, you would have to find some 8 lug hubs for it, or find someone to recenter the Hummer wheels to 6 lug or whatever you have
Just a little buggy
Old 12-13-2006, 07:28 AM   #23 (permalink)
Member # 14004
I've run stock and recentered H1 wheels on an 8 lug D44 front. You need about a 1.5" spacer to clear the TRE on the stock wheel. I think you would have to move the steering behind the axle to use a hi-steer setup.
