need some help/info about a rear D60 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-03-2006, 06:48 PM   #1 (permalink)
Member # 53129
Send a message via AIM to fluidmotion
ive got a full floater D60HD axle. the shafts are 30 spl 1.25" diameter. when i look for lockers and gears do i have to get anything special or will the regular D60 stuff work? (standard rotation gears, standard bearings, 30 spl locker)
also i cant figure out what it came off of. the BOM number is 603237-2 and the date code is 1-16-3A1. can anyone tell me what its from?
fluidmotion is offline   Reply With Quote
Old 12-03-2006, 08:48 PM   #2 (permalink)
Phantom1016's Avatar
Member # 67642
There really isn't a "regular" d60, tell your supplier you need a 30 spline, 1.25" shaft version, he might not know what HD means. Also, thought I'd help you out and look up the BOM for you:
Year: 71-75
Model: D200/W200HD
Gears: Std
Differential: Trac-Lok
BoM: 603237
Hope this helps!
"I can do all things with a sawzall who strengthens me" - Philippians 4:13, or something like that
Phantom1016 is offline   Reply With Quote
Old 12-03-2006, 10:38 PM   #3 (permalink)
Member # 53129
where did you look that BOM number up at Phantom? i tried at the dana expert site and it couldnt find it for me
what i ment by regular was if the bearing size was bigger on mine or anything like that since it is heavy duty
Old 12-04-2006, 09:53 AM   #4 (permalink)
Member # 67642
I googled for rear dana BOMs, took a couple tries but fianlly got a hit. I'm pretty sure gears are the same, but like I said, you're locker won't be.
Old 12-04-2006, 12:41 PM   #5 (permalink)
Member # 53129
thanks for the help phantom. i called randys ring and pinion today and talked with them about the axle. everything should be good to go for my project
