YJ Dash Question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-04-2006, 07:44 PM   #1 (permalink)
Member # 50240
YJ Dash Question
Does anyone know if it is possible to change from the original dash(of a YJ) to a CJ dash??
NattyDread is offline   Reply With Quote
Old 12-04-2006, 11:07 PM   #2 (permalink)
Member # 74950
yes. get a red star and search. or try google, there was a webstie with the same idea
kab5437 is offline   Reply With Quote
Old 12-05-2006, 03:15 AM   #3 (permalink)
Member # 47977
yes, I am in the process of putting one in my project. So far all bolt holes line up. The defrost ducts are going to be an issue. I don't like the dash pad so I likely won't use it. Wiring ... I'm using a 401 in the yj so I won't need all the yj stuff. I think off-road had an article on this somewhere on the web.
Big Round Speedometers are Cool!!!
hope this helps
k
88 YJ Build, AMC 401,727,Dana 300, D60, 14 bolt
ksmith is offline   Reply With Quote
Old 12-05-2006, 09:09 AM   #4 (permalink)
89breaker's Avatar
Member # 64213
Defroster duct solution:
Cut holes for the factory ducts. Then either use your original dash pad or be like me & fab up a dash box with integrated defroster ducts.
89breaker is offline   Reply With Quote
Old 12-05-2006, 01:47 PM   #5 (permalink)
matts88yj's Avatar
Member # 62615
89breaker - any pics of your dash setup? Im looking to flat dash mine as well and this is pretty much the only snag I can think of. Thanks!
Matt
Unstacking Hardass
matts88yj is offline   Reply With Quote
Old 12-10-2006, 10:40 AM   #6 (permalink)
89breaker's Avatar
Member # 64213
No problem, I will take some tonight.
The dash has been pulled (electrical problems) until recently.
Old 12-11-2006, 12:22 PM   #7 (permalink)
matts88yj's Avatar
Member # 62615
Ok sweet! Thanks for postin them up!!! Im doing some small metal fab and wanted to see what all you did to them. Thanks again!
Matt
Unstacking Hardass
Old 12-11-2006, 01:56 PM   #8 (permalink)
89breaker's Avatar
Member # 64213
Dash pics
Disregard the loose wires & dirt......I'm not done.
For the defrost, I am using the stock pad until I can fab up a dash box with defroster ducts.
Also, if you google this subject, you will get about a week's worth of reading.
