Pass knuckle D30 (1) hole stripped..How to fix? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-15-2006, 04:51 PM   #1 (permalink)
Member # 69083
My Pass knuckle D30 (1) hole is stripped.Is it possible to fix or should I just replace it. I read something about drilling a hole and using a nut and bolt ?? Any ideas or pictures?
Matt -
blackjeep04 is offline   Reply With Quote
Old 12-15-2006, 08:45 PM   #2 (permalink)
nhgpnut's Avatar
Member # 42521
Send a message via AIM to nhgpnut Send a message via Yahoo to nhgpnut
Not sure what bolt hole your talking about but most likely you should be able to repair it. Take the bolt with you to an auto parts store and tell them you need a heli-coil to repair that size hole. The kits usually come with instructions and have more than one in the kit,good to keep with you on the trail.
If you have it, a truck brought it. Without trucks,you would be naked and hungry.
nhgpnut is offline   Reply With Quote
Old 12-15-2006, 08:55 PM   #3 (permalink)
Member # 21815
Far as I know, the only threaded hole on a 30 knuckle would be the steering stop...Stripped or not, throw a bolt in it, adjust it, and throw a quick tack on it...done.
WWDD?
N6YBH
"If you need a tool and don't buy it, you will ultimately find that you have paid for it but don't have it". -Henry Ford
Use Goodsearch and support the Rubicon Trail Foundation.
resqme is offline   Reply With Quote
Old 12-17-2006, 03:02 PM   #4 (permalink)
Member # 54940
Are you talking about one of the caliper bolts?
I heli-coiled one on my Dana30 right before I ditched it.
95 YJ with a few mods
OhioYJ is offline   Reply With Quote
Old 12-17-2006, 03:58 PM   #5 (permalink)
Moderator
apeters89's Avatar
Member # 7647
could also be one of the unit-bearing bolts if it's a newer Dana 30.
edit: wait, if I remember right now, those bolts actually go through holes in the knuckle and only thread into the bearing.
Check out our new Team Ape Eater Racing Like us on FaceBook
KF5EQF
Sniper Fab
4x4Oil SBwinVPS Custom Splice C2GFab
apeters89 is offline   Reply With Quote
Old 12-17-2006, 04:41 PM   #6 (permalink)
Member # 69083
You hit it on the nail..What size was the heli-coil that you used if you remember? My D30 is off an 04'.
Matt -
Old 12-17-2006, 07:11 PM   #7 (permalink)
Member # 54940
I want to say it was something like M8x1.25, but I'm not really sure, I got it from AutoZone, I just took in one of my caliper bolts to match it up to the correct kit. The kit cost me about $25, then I had to go to the hardware store because the heli-coil kit needed some odd-ball drill bit size the parts store didn't have.
It worked great, thhough, even if it did cost me like $30.
