NOBAMA!
Member # 68916
78 F250 D44...knuckles
Are the knuckles on a 78 F250 8 lug D44 flattops? The driver side appears to be, but what about the passenger side?
Im removing the tubes and moving the pumpkin to passenger side for my CJ. What should I run for outers and brakes? |
Member # 77718
Yes it's a fat top. Mine is a '79, but the same axle. If you run these knuckles, you are stuck with the outers, wich isn't bad, big brake wise, but you have to run 16" or bigger rims.
'89 B2 with slight modifications [QUOTE=AZFord4x4;8084876] I really shouldn't download so much porn while I'm trying to ban people.[/QUOTE] |
Member # 77718
Yes you do have to run the entire Ford outer if you run these knuckles.
small bearing spindle and knuckle and outer from Blazer or pickup from mid to late 70s will work with Ford brakes and rotors.
http://77cj.littlekeylime.com/flatop_knucles.html Best site out there for D44 and flat tops.
Only in a Jeep |
#12 (permalink) |
NOBAMA!
Member # 68916
Ok heres another question for you. Im retubing the 44, moving the pumpkin to passenger side and want to run waggy width. The rearend is an XJ 44 going under my CJ so I want it to be around that width. So Im thinking about getting alloys to begin with and then carrying waggy axles as spares. Would I run the FSJ knuckle to be able to use the waggy outer? This is the part that confuses the hell out of me.
#13 (permalink) |
Member # 83941
You might run into driveline issues with a high pinion in a CJ depending on your lift height, I would narrow a chevy 44 to waggy width and run junkyard waggy axels. Much cheaper, and easier. Depending on your tire size you can break alot of 12 dollar axel shafts and still be under the budget of a retubed HP44.
5 on 5.5 Ford hub, chev BP, caliper and small bearing spindle, with flat top chev or jeep knuckle is the outer combo I have used in the past. Worked great. Good Luck. |
#15 (permalink) |
Member # 116
Find yourself a wagoneer 44, with the diff on the right side. Then you just have to shorten one side to make it stock length. Then use the GM flat tops with the early small bearing spindles as previously mentioned. Then get the big GM mounting plate like from a Suburban, and calipers. Then get the Ford 1/2 ton rotor and hub. You will get 5 on 5-1/2. That's what I did.
"The problem with socialism is that you eventually run out of other people's money." - M. Thatcher |
