Member # 81115
2 stick, cut out, line lock steering
What's the scoop on this?
Near as I can tell, people put independant line lockers on the back wheels (one each), and some kind of "cut out" (one each?) on the front, then by utilizing neutral on the tc effect power slide turns. What hardware is used for the cut outs? how exactly does one shift the front/back while utilizing these break system modifications? |
they are called cutting brakes. you disconnect the rear driveshaft and use front wheel drive only. the rear is not being powered, so if you use the cutting brake on one wheel, it locks, the other free spins. its called a front dig.
[B][CENTER][SIZE="6"][FONT="Impact"][COLOR="DarkRed"]Temet Nosce[/COLOR][/FONT][/SIZE][/CENTER][/B] [QUOTE=ashmanjeepXJ;7641445]All you will probably ever have in common with this forum is a steering wheel. [/QUOTE] |
#3 (permalink) | |
Addicted to Gear Oil
Member # 56050
They are called "cutting brakes", and to use them they do a "front dig" to turn tighter. It requires modification of the transfercase to allow you to shift into F(ront)WD or R(ear)WD or 4WD, not all transfercases can be modified for this though. Dana 300, Dana 20, NP 205 are some popular xfercases than can be modified. Atlas and Stak 'cases are already made for it. Chaon driven 'cases like NV231/241 can not be modified for FWD. Cutting brakes can be cable actuated like an emergency brake or plumbed hydraulically in to the brake system.
Edit: Damn I type too slow...
1965 Scout 80 7.3PSD/ZF/203/205 D60F/14BFF Member: 4 Jackstand Wheeler's Association Quote:
David H. Petraeus for President 2016Last edited by guidolyons; 12-20-2006 at 06:02 PM. |
Member # 81115
so, are the "cutting breaks" simply 4 line lockers? I assume a back dig (reverse, neutral front) is also possible? For example, If I wanted to shift the rear to passenger, I might turn hard passenger, line lock the passenger front, disengage front and romp it once in reverse.
I have a 4sp atlas so have everything but high fwd only.In the olden days we had these red "micro line lockers" that had this camed handle. You just mashed on brakes and pulled up the handle. I think they were used mostly on trackors ... I'm having a hard time finding any of these anywhere? |
Member # 81115
another example, The other night we are on a dirt road with a foot of snow. We slide off the road, both driver side wheels in a 3' drop while passenger side still on the road. Not really stuck, but can not get turned back on road, stuck running the rutt as it where, but would never get out of it forward or back, it seems if we could have line locked both passenger wheels, the jeep would have pivoted 90 and let us back on the road. Does this work in practice?
Member # 39935
i have cutting breaks. i got mine from poly performance. the company makes them is cnc. it is like a master cylinder will and handle and no reservoir you pull or push the handle and it pumps the brakes thus locking them up. they sell and dual piston and single piston. i have the dual one and each rear brake has its own cutting brake so they can be controled seperately. here is the link. http://www.polyperformance.com/shop/home.php?cat=381. i have this only on the rear. i have not seen a jeep/buggy have them on the front. i dont think you would need them on the front brakes.
'93 YJ Trailer Queen '04 Chevy Dually Tow Rig Last edited by redsandman6; 12-20-2006 at 07:32 PM. |
#7 (permalink) | |
Member # 24640
The presence of lockers would prevent you from doing what you are describing
Co-Driver 4447 Camco Rock Racing Thanks to our partners: Bulldog Winch, Jackson Powertrain, Winchline.com, BFG, Raceline wheels |
#8 (permalink) | |
Member # 81115
Very cool, thanks ... now I understand what they mean by "cutting breaks". Question ... is there a lock out on those handles? In other words, can you use these as line lockers also? If not, do you still find at least a single line locker (lock all four wheels) for e-break/winching break .. to keep presure off your parking pawl? |
#9 (permalink) | |
Member # 56050
It's a MICO line lock, not micro. http://www.mico.com/products/displaysubinfo.php?id=43
BREAK is what happens to you when your BRAKES don't work and you hit a tree.
David H. Petraeus for President 2016 |
#11 (permalink) | |
Member # 81115
Thanks for that link (and the spelling lesson). |
#12 (permalink) |
Member # 11570
There are two different products being talked about here:
1) Line Locks, which are block off valves that go into the brake lines. To do a cut with those, you'd stomp on the brakes, then flip the switch to lock up the tire of your choice(closes the valve to keep pressure in that line), then you let off the brakes. The other wheels are released. 2) Cutting brakes. These really come from the dune buggy world(and other places). Most good dune buddies have them, because the front ends are so light they just plow straight ahead at speed in the sand. These actually have a master cylinder in them. So pulling the level will engage the brake without touching the brake pedal. You can get single levels, or one that will lock one wheel if yo push forward, and the other wheel if you push backward.
Swamp Stompers 4x4 Club |
#13 (permalink) | ||
Member # 56050
David H. Petraeus for President 2016Last edited by guidolyons; 12-24-2006 at 03:33 PM. |
