Clutch hose fittings - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-01-2007, 08:59 AM   #1 (permalink)
Member # 78408
Does anybody know what the correct size fittings are for the clutch hose on an 88 YJ with the 4.2L?? My hose burst and I don't want an OEM replacement so I need to get hose and ends to make my own.
Thanks.
KC2OTE is offline   Reply With Quote
Old 01-01-2007, 04:40 PM   #2 (permalink)
Member # 70172
Use brake line. Take out the plastic clutch line and use it as a template to bend, cut, and flare a line - this won't break. Another option is to use a flex brake line if you have the extra cash and desire more flexibility.
Alfons is offline   Reply With Quote
Old 01-02-2007, 03:47 AM   #3 (permalink)
Member # 78408
What's there now is hard steel line (brake line) with about 4 inches of rubber line in the middle so the drivetrain can move. I want to replace the whole thing with braided steel line but need to know what size hose and fittings to order.
Old 01-02-2007, 08:37 AM   #4 (permalink)
Member # 37184
Remove your current fittings and measure OD and thread pitch. To run braded line, you'll probably want to use AN fittings. You'll need ASE (your current fittings: 45* flare) to AN adapters (37* flare). I think Advanced Adapters sells the adapters and hose; look in their clutch section. Also peruse SummitRacing.com for brake line fittings.
Bubba_Jeep is offline   Reply With Quote
