Death Wobble - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-11-2007, 03:07 PM   #1 (permalink)
Member # 85165
Death Wobble
I just got this jeep it's a 89 wrangler and it was perfect i drove it from la to monterey and then me and some friends took it mudding and when i was driving back it started to shake out of control at random times what can i do about it?
rotctorre is offline   Reply With Quote Quick reply to this message
Old 02-11-2007, 03:18 PM   #2 (permalink)
Hackfabricaton's Avatar
Member # 70509
Take the Jeep to a car wash and clean off all the mud from the inside of the wheels.
If that doesn't 'cure' the shakes. Check the tie-rod for damage. Then check the driveshaft for damage.
Assuming the Jeep ran fine before you went out and wheeled it, then the damage was caused in the mud.
You didn't jump it....Did you?
"In the end...It's all Hack."
Hackfabricaton is offline   Reply With Quote Quick reply to this message
Old 02-11-2007, 03:37 PM   #3 (permalink)
Member # 85165
no we just ran it across and slid and climbed some hills but nothing to go airborne
Old 02-11-2007, 03:48 PM   #4 (permalink)
Member # 82521
If itís not one of Hacks suggestions then check the tire balance. Maybe one of the weights fell off while you were wheeling. You would be surprised what unbalanced tires will do on the front end.
Kriss
Saddle Tramp is offline   Reply With Quote Quick reply to this message
Old 02-11-2007, 04:32 PM   #5 (permalink)
Member # 65138
Send a message via Yahoo to machine
Is it @ a certain speeds? Check the driveshafts u joints for breakage. Lost a weight on one of the wheels. Check the front track bar/ steering for loose parts. Got mud caked on the driveshaft causing a balance problem. There are tons of reasons. You'll have to get under there check it out.
machine is offline   Reply With Quote Quick reply to this message
