AX15 to NV3550 conversion - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-18-2007, 10:11 AM   #1 (permalink)
Member # 37924
I have an NV3550and attached transfer case that I want to swap out for an AX15 currently in a Jeep Wrangler 4cyl. What would I need besides a bell housing for the conversion? Any places to look for bellhousings and what potential problems have you all that have made the conversion found in the process? Thanks
saint056 is offline   Reply With Quote
Old 02-18-2007, 02:05 PM   #2 (permalink)
Member # 84269
first, ax-15 only came behind the 6 cylinder 4.0L engine. the 4 cylinder had the ax-5.
second, your question states that you want to swap the nv3550 out, and put an "ax-15" in. why would you want to do that? the nv3550 is a better trans. if that was a typo and you are swapping an nv 3550 into your jeep then check out this place...
http://high-impact.net/transmission_and_gear/index.htm
they have what you need to swap the nv3550 into any jeep.
good luck
heeps4ever is offline   Reply With Quote
