Member # 87087
anyone ran a aussie in the back of there jeep?
i have a 8.8 in the back on my tj and i found a used aussie for $125, i dont really have the funds for a selectable locker yet so im thinkin of buying this. but i would like to know how the ppl that run these liked it.
Member # 32034
i don't run one, but the only drawback i can say about it is that it's clutch driven, not gear. it's really a limited slip that has an electrically actuated lockup. but the locker never really locks up completely like a gear driven locker and the clutches can wear out.
for $125, if it's in good shape seems like a good buy though. |
#3 (permalink) | ||
Member # 17311
Nex Pro Evinco "Death Before Defeat" |
#4 (permalink) | |
I had a buddy with a Lock-Right in the back of his TJ. personally, I wouldn't run one for a rear application, especially in a TJ. It caused some quirky "jacking" of the rear axle and the forces oblonged the bolt holes in the stock control arm mounts. For my $$$, I'd either install a spool or a selectable. Those lunch box lockers just shock load too bad for a rear axle in my opinion. Oh, and check that thing out closely before you pay for it. When Lock-Rights get used, the clutch teeth wear out. When the teeth wear out, the locker doesn't engage right. If it's not engagig right, you may be stuck with no wheel drive instead of 1 or 2. |
Member # 75158
Run it, you will be happy. I have an 8.8 and have run it for 4 years of hard rockcrawling and never a problem. I even managed to break an axle shaft in the 8.8. The only shock load would be in a sharp turn if you let off then push on the pedal in the middle of the turn you will feel it. Not hard to get used to. Either accellerate through the turn or make the turn then accelerate as you straighten out.
Member # 58117
I learn a lot from reading these post. I have an Aussie in my front axle and love it. A buddy asked me about installing one in his D44 (rear axle) and I told him I don't see why not, just understand the quirks of an auto locker in the rear axle. I guess time will tell if I gave my buddy bad advice or not.
