14bolt disc brake - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-27-2007, 12:10 PM   #1 (permalink)
Member # 68165
14bolt disc brake
Heres the question, I have a set of 75 chevy frt disc brakes on my rear 14bolt, for the disc brake conversion, I need to hook up a emegency brake on the rear axle. What im looking for is a rear caliper that would bolt on to my setup I have wit the e-brake setup on it. I havent done any research on this topic as of yet just thought I would start here and see what I could come up with. Any help would be great.
Thanks
Grounhog is offline   Reply With Quote
Old 02-27-2007, 02:04 PM   #2 (permalink)
nofender's Avatar
Member # 25958
79ish Caddy Eldorado. I forge the exact spread in years. But it's somewhere in there.
Good luck. they are a pain in the balls to set up right.
nofender is offline   Reply With Quote
Old 02-27-2007, 02:48 PM   #3 (permalink)
Member # 68165
That what Im hearing, there is nothing else out there.....ANYBODY....
Old 02-27-2007, 04:40 PM   #4 (permalink)
nofender's Avatar
Member # 25958
Pretty much no. If you want a bolt on affair, that is basically your only option. You could look into a t-case mounted e-brake.
Old 02-27-2007, 05:06 PM   #5 (permalink)
Member # 68165
The t-case brake sounds interesting. In the little research I have done, I have come across a line-lock type parking brake, are these any good for anything or are they pretty much junk? I guess Im just looking for the pros and cons of this type of setup?
nofender thanks for all the input you have been a big help.
later
Old 02-27-2007, 05:06 PM   #6 (permalink)
onesun06's Avatar
Member # 69163
You are going to want to look for calipers for a 76-78 El Dorado...pretty sure those are the only ones that will work....you are going to be looking at $75+ per side for re-manufactured ones, too. I've heard the cheaper $75 don't come with much hardware...like the spring and cable connection tab.
I plan on going this route for my 14B before summer. I also plan on looking into line lock as an alternative.
onesun06 is offline   Reply With Quote
Old 02-27-2007, 05:54 PM   #7 (permalink)
Member # 5436
I was talking to Ben from OTT about this subject last week and he suggested using late 70's deville calipers, instead of the eldorado ones. the Deville was a full size instead of midsized like the eldorado, so better stopping power and the ebrake holds better. Also I've heard of guys having problems fitting the eldo calipers on the 3/4 ton rotors because of the width, apperently the deville's are the correct width. I havent checked any of this out myself but that guy knows his stuff so I'd bet he's right. Has anyone else tried these?
YOU are paranoid.
monzter is offline   Reply With Quote
Old 02-27-2007, 06:16 PM   #8 (permalink)
LCAC_Man's Avatar
Member # 35307
I used 77 Eldorado calipers on mine with the Great Lakes brackets and 77 Chev 3/4 ton rotors, fits up great, still be awhile before I can put them to use though.
Len Barron
72 Commando/LS2/4L65e/NP241
DRWHP60-ARB/14B-Detroit/4.56/H1's/37's
Bullnose Build in Progress
Stretched Bullnose
LCAC_Man is offline   Reply With Quote
Old 02-28-2007, 08:47 PM   #9 (permalink)
Member # 18908
These should do the trick:
http://www.tsmmfg.com/3120.htm
oltmann is offline   Reply With Quote
